09-06-2013, 02:18 PM | #21 | |
Re: painting engine
Precision Engine & Mach 3425 Brooks Drive Sun Prairie, WI. 53590 608- 837-7174 When I Googled the address, the location is now a mini storage warehouse. The Ph # is now a private number. The PO claims that when he decided to start the project he called Ford for advice and they recommended Precision for his engine rebuild at that time. Gun bluing sounds like a very good idea. Thanks Tom. |
09-06-2013, 02:54 PM | #22 | |
Re: painting engine
IMG_1280.jpg IMG_1279.jpg Quote:
Yep. If I am wrong I hope somebody corrects me soon. |
09-06-2013, 07:46 PM | #23 |
Re: painting engine
I have never seen them before. I just checked the Brattons catalog and could not find them listed in the engine parts section. I did find them listed in the Snyder catalog, they are for an aluminum head. Is yours cast iron or aluminum?
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts http://www.fordbarn.com/forum/group.php?groupid=5 |
09-06-2013, 08:40 PM | #24 |
Re: painting engine
Ed is correct. the washers are for use with an aluminum head. I wouldn't use them with a cast iron head. Washers under the head nuts would effect the height that the studs rise above the nuts. The picture looks like they are already kinda low, except for the ignition stud.
09-06-2013, 09:13 PM | #25 |
Re: painting engine
Skeezix,
Gregg screwed up & put the longer stud in the WRONG hole, I'll disguise it with a CHROME ACORN COVER! You think the JUDGES might miss it?? I have 2 creepers & yo' "MECHANIC" is welcome to come doodle with me, under my spiffy, BLACK, DODGE-KADOTA, with a BLACK tarp & wide BLACKWALL tires. The KADOTA is kinda' tall & we won't even have to jack it up! I'm blessed to be kinda' skinny too & my jackstands are collecting cobwebs! They still look like NOS-HARBOR FREIGHT! Bill W.
09-06-2013, 09:27 PM | #26 | |
Re: painting engine
09-06-2013, 09:33 PM | #27 | |
Re: painting engine
It's kinda funny, the nuts themselves aren't too bad it's the washers under them that got rusty. At any rate ....they gotta go. |
09-06-2013, 09:40 PM | #28 |
Re: painting engine
I agree also. A brush painted engine can look mighty fine - I know.
09-06-2013, 11:46 PM | #29 |
Re: painting engine
Do you use the paste or liquid? Do you clean the rust first, & if so what works best?
09-07-2013, 03:21 AM | #30 |
Re: painting engine
I use the liquid and kept rubbing it in for about 3 minutes to 5 minutes. I sanded my gun barrel with my 1/4 sheet palm sander, then warmed the barrel with my heat gun to about 125*. This is about the same as a tool that lays in the hot sun. After rubbing in the G-96 I rinsed it with hot water and dried it with a towel, then rubbed it with ATF.
09-07-2013, 09:31 AM | #31 | |
Re: painting engine
09-07-2013, 01:41 PM | #32 | |
Re: painting engine
09-14-2013, 09:47 PM | #33 |
Re: painting engine
All prepped and ready for painting tomorrow. I'll post pics.
I have one other question first. When I removed the manifolds I noticed no gland rings. Andrews says just use the copper gaskets and no rings. I have a one piece gasket not the copper ones. Is it going to leak? |
09-14-2013, 09:58 PM | #34 |
Re: painting engine
I would suggest masking up the fenders, firewall, and cowl better. You may not need to but better safe than sorry. You could also claybar the paint with soap and water after you paint the motor to remove any over spray. Steel wool will clean over spray off glass. But if you're brush painting, ignore all that I have said. Good luck!
Cowtown A's |
09-14-2013, 10:49 PM | #35 | |
Re: painting engine
10-09-2013, 11:06 AM | #36 |
Re: painting engine
As per Buster T's request here are the before and after pics.
10-09-2013, 11:32 AM | #37 |
Re: painting engine
Does it go faster now? Looks good.
10-09-2013, 11:47 AM | #38 |
Re: painting engine
