Old 01-20-2017, 07:26 PM   #121
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Pulled my spare engine apart for inspection
Originally Posted by C26Pinelake View Post
Congratulations! Now that you have an excellent spare the original motor will never break down! Wayne
Isn't that the truth. I was recently given an engine that has been a club member's "spare" for ~40 years. He said it came with his car and has been sitting in his garage all this time.
Old 01-20-2017, 08:06 PM   #122
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by Art Newland View Post
Tom, you must be psychic. Started to clean it up, and a big chunk fell out!
That would make a good cutaway display item.
Should be easy to cut with most of the metal rusted away.
Old 01-21-2017, 12:15 PM   #123
Art Newland
Art Newland's Avatar
Yea, yea, rub it in!
Going to pick up another head this morning. $25 bucks can't get hurt too bad.
Art Newland is offline   Reply With Quote
Old 01-23-2017, 07:26 PM   #124
Art Newland
Brumfield head installed, started right up. Seems to run about the same, sounds the same to me.
https://www.youtube.com/watch?v=UABt...ature=youtu.be
Old 01-23-2017, 07:35 PM   #125
Dick Steinkamp
Dick Steinkamp's Avatar
Did the compression come up?
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 01-23-2017, 07:44 PM   #126
Art Newland
Probably.
I'll re-torque in the morning, run it again and check the compression while it's warm.
Old 01-23-2017, 07:57 PM   #127
Tom Wesenberg
If this is that $25 head, you sure got lucky.
Old 01-23-2017, 09:15 PM   #128
Art Newland
Yep, $25 bucks. He had several stock heads too. He knew it was a high compression head, I even remarked to him that a Synders 5.5 was $300. And asked if he was sure he wanted to part with it. A stock head would have been fine with me, but since he didn't care I thought it would be an interesting experiment to try it out. It certainly didn't fit down over the studs as well as the one I pulled off, and the distributor seems to set a wee bit higher making the spark-plug wires seem a tad too short. I took a peek at the honing marks in the cylinders while I had the head off, they are still there for the most part but you can tell it is wearing in. He has a Fordor for sale for $5000 too if anyone's interested. A pretty complete car that does run and drive.
Old 01-24-2017, 05:42 PM   #129
Art Newland
CHA-CHING! Maybe a little more with some run time on it?
76,75,75,75.
