03-10-2015, 07:19 AM | #41 |
Re: How To Lower The Model A The Old Fashion Way
I would like to know
1: can you use model a perch pins in a 32-36 front axle 2: can use use model a spindles and king pins in a 32-36 front axle? 3:how can you lower a model a rear spring at home besides removing leafs?? 4: what year model t rear springs are you guys using? And what years fit On a model a rear end? Thank you |
03-10-2015, 07:56 AM | #42 |
Wow! It really looks nice. I like the wheels.
03-10-2015, 08:24 PM | #43 |
Thought I was on the HAMB here...whoops !
03-10-2015, 10:24 PM | #44 |
I think it looks great!
Denny |
03-29-2015, 09:04 AM | #45 |
06-30-2016, 10:52 PM | #46 |
Forgot to add that I am using 31 backing plates and drums, not the 32 backing plates or drums Thanks for your time Last edited by Judson; 06-30-2016 at 11:13 PM. Reason: left out important information |
09-22-2016, 09:30 AM | #47 | |
I'd like to use a 33-36 axle with 32 spring perches and 31 brakes&spindles. Is there an urgent need for 32 spindles? Greetings Daniel |
09-22-2016, 10:44 AM | #48 |
Why did you want to lower it ? Were you not satisfied with an original looking Model A ? Wayne
09-22-2016, 11:57 AM | #49 |
The steering arms mount to the top of the Model A spindles and are on
the bottom of the 32 spindles so you need to check for tie rod interference with the wishbone and frame and see what works best for you. Bob |
09-22-2016, 04:42 PM | #50 | |
Thanks
-*Get your kids addicted to cars at an early age...they won't have any money for drugs*- |
09-22-2016, 06:47 PM | #51 |
You can use the A spindles by cutting the balls off and welding in new ones from the other side.Or drill and tapered ream. Weld in and bolt in balls are available from most suppliers.
The tapered bolt in ones are 32 so the Model A parts guys mightn't have them. You can get them from Mac's. Last edited by Manager; 09-22-2016 at 07:24 PM. |
09-23-2016, 12:49 AM | #52 |
32-34 axle, 32-34 spindles, Model A King Pins, 32-34 spring perches, Model A brake actuators, 32-34 Brakes. Works great.
I don't know what to use if you use Model A brakes. The 32-34 King pins are at the wrong angle as are the actuators. I just did this swap and getting ready to do another one. You also need to make up a 5/8 spacer to put under the leaf spring if you run a reverse eye front spring with less leaves, I used the one from Speedway. And yes you can use the Model A spring perches if you use hydraulic brakes. Mechanicals need the 32-34 |
09-23-2016, 11:08 AM | #53 | |
Thanks for the info!
09-23-2016, 11:12 AM | #54 |
Thanks for the info, I have an extra steering arm i might attempt to heat and bend. Possibly shorten it if needed to keep the original drag link length for lock to lock steering. If I find a way that works I will post picks. I'm running a 2 1/4" drop A axle, modified A perches, A kingpins, A spindles, original front A spring and A mechanical brakes and modern tube shocks.
-*Get your kids addicted to cars at an early age...they won't have any money for drugs*- Last edited by kkarlsrud; 09-23-2016 at 11:17 AM. |
09-23-2016, 12:22 PM | #55 |
Just to confuse a little more. Here is my "A" dropped axle with stock spindles and mech. brakes and stock spring perches. I had to flip the balls so to speak to clear steering rod between wheels.
09-23-2016, 12:29 PM | #56 |
Thanks for the info and pics zzlegend. That is exactly what I was thinking I would have to do. It helps to see what needs to happen. Also, did you use a shortened tie rod as your drag link to get the correct angles from the pitman arm?
09-23-2016, 12:42 PM | #57 |
Yes. Made an adjustable one and also installed a new short pitmen arm from Bert's model a. Hope this helps.
09-24-2016, 06:36 PM | #58 |
My '29 cabriolet has the original front axle dropped 2-1/2", a reversed eye front spring, and revered eye rear spring. ...a few other changes, but still running a touring built Model A motor.
Purchased new in November 1929 by my father. Original color was Andalusite Blue, now with a little of the black pigment pulled out of the old PPG formula. I have not previously posted a full shot of the car, but since others have posted pics of their modified, lowered A's and this is not a street rod, I guess it is OK in this instance. |
09-27-2016, 11:55 AM | #59 |
Great looking Cab! It's more than Okay!
Keep 4-Banging!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
09-27-2016, 12:48 PM | #60 |
ZZlegend What shocks are those?
Blackwall Panthers Nor Cal chapter |
