Old 11-20-2010, 11:04 PM   #1
Rustyspokes
Rustyspokes's Avatar
Default Master Battery Disconnect Switch
Where is a good place to mount a Master Battery Sw. I have a 34 Ford and I am at ends as to where would be a good location, anyone installed one ,? your info would be greatly appreciated, tks Barners ..
Rustyspokes is offline   Reply With Quote
Old 11-21-2010, 04:30 AM   #2
flatheadfan
flatheadfan's Avatar
Default Re: Master Battery Disconnect Switch
D(AL)-
When I was looking for a place to install a cut-off switch I didn't want to drill a hole in the floorpan nor did I want to drill a hole in the firewall. The only place left was the engine compartment, which worked out great. I didn't need to drill any holes I only needed to use existing frame holes. A simple bracket and one short cable and I was in business. One neat thing about its' location is it allows for easy battery charger or battery tender hook-up without having to pull up the floor mat, remove the battery cover and leave the door open.
Tom
flatheadfan is offline   Reply With Quote
Old 11-21-2010, 10:27 AM   #3
G.M.
With the battery under the seat the best place is the seat riser under the front of the seat. You need a few short cables to put it in the POS side between the battery and ground. You don't want a cheap shut off, they will give you problems on 6 volts. Bob Shewman the flex hose guy has a real good one that can mount on the battery terminal or on the seat riser. You don't want a battery mounted one on the battery's that are under the floor. Contact Bob at [email protected] or 1-610=933-6637 G.M.
www.fordcollector.com
