05-12-2020, 08:07 PM | #1 |
Re: 1930 Tudor door glass
Tom : I'm restoring a 1930 Tudor. The rear glass can be removed by removing several small bolts ( machine screws) from the D nut, same to install steel plate after installing the felts , top sponge, and glass. On the doors there is a top metal plate that can be removed by removing 3 or 4 small bolts ( machine screws), giving access to the felts. After installing the glass, felts, and plate, glue in the top sponge to complete the installation.Hope this helps you. Regards Grant
05-12-2020, 09:07 PM | #2 | |
Grant: Many thanks. I had previously looked on the top of the doors thinking there may be screws there, but I did not see any. I looked again after your post and found them. There are three on the top of each door and they are buried in paint and crud and sit down in a groove. Tom Endy |
