10-23-2011, 03:09 PM | #1 |
1935 Horn Rod
After looking for over a year plus I finally found a near perfect 1935 horn button and rod....when I got it it was bent and mangled so badly that I do not think it can be ever straightened,.. it actually got corkscrewed. I was soooo bummed! Does anyone sell the rod with the proper crimp at the end and slot for the c clip? It doesn't look that hard to farbricate...but where would one get the rod? Any help or advice is greatly appreciated....as always thank you .......Matt in Alameda
10-23-2011, 03:21 PM | #2 |
Re: 1935 Horn Rod
To my knowledge no one repos the tube. You will have to make your own. You may be able to use each end. A 14 ga. wire goes down the tube so there is room to put a sleeve inside each end so you can attach a new tube.
10-23-2011, 04:32 PM | #3 |
Re: 1935 Horn Rod
