10-23-2011, 12:29 PM | #1 |
Front Leaf Spring U Bolt Torque
Hi All
I replaced the anti-squeak pad when I bolted the axle back on. The replacement from Macs is a thick piece of canvas webbing. I cut the hole for the leaf spring bolt and secured the pad with electrical tape to keep it from moving. The head of the bolt is seating in the square cut-out in the front cross member. The problem is I'm REALLY having to tighten the nuts with a breaker bar to get the cotter key openings to align. I tightened it as far as I dared and still couldn't get the cotter pins in so I backed it off. Is is possible to overtighten or strip these or am I just being a wimp? Thanks! |
10-23-2011, 12:52 PM | #2 |
Re: Front Leaf Spring U Bolt Torque
I suspect that your problem is that you haven't set your car down yet. The weight of the car will be a big help in pulling down the u bolts. I'm thinking the amount of force required to pull the spring down with only the u bolts would exceed the normal torque limits of the threads.
Alan |
10-23-2011, 12:57 PM | #3 | |
10-23-2011, 03:37 PM | #4 |
Paul in CT |
