10-21-2011, 06:40 PM | #1 |
Fuel Leak
What is the best way to fix a fuel leak, comming from the fuel pump? Ive got a 1949 Ford Custom
Joshua Landvik |
10-21-2011, 06:47 PM | #2 |
Re: Fuel Leak
where on the pump is the leak?
10-21-2011, 07:56 PM | #3 |
Re: Fuel Leak
Either you got a pinhole in the diaf or you have a leaky valve in the pump.Some glass bowl pumps can and should be rebuilt not buy new China made ones which are junk as far as im concerned.Charlie stevens on here or chevy barn has a pic up there of 1 that can be done.Split it and take a look. This is i assume is a single action one.ken ct.
10-21-2011, 11:17 PM | #4 | |
Re: Fuel Leak
10-21-2011, 11:19 PM | #5 |
Re: Fuel Leak
10-22-2011, 12:57 AM | #6 |
Re: Fuel Leak
10-22-2011, 12:10 PM | #7 |
Re: Fuel Leak
10-22-2011, 03:51 PM | #8 |
Re: Fuel Leak
Whenever I've had leaks like you've described I've always been able to stop them by tightening the fittings and the screws around the top of the fuel pump. If you haven't done that yet it may be a quick fix.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
