11-29-2023, 12:52 PM | #1 |
64 falcon
Hi guys, I have a 64 Falcon with the Ford O Matic (not cruise 0 matic) tranny. The o ring on the kick down lever is leaking. Can I drop the pan and replace the O Ring with the tranny in the car? Wish it had a seal instead of o ring.
thanks al |
11-29-2023, 06:34 PM | #2 |
Re: 64 falcon
OK I pulled the pan, and there is no way to replace the o ring without dropping the entire valve body out of the case. You cannot slide the shaft out with the valve stack in the case.
O well that is how my luck goes. |
11-29-2023, 06:43 PM | #3 |
Re: 64 falcon
You have the F/M/2, correct?
Dropping the valve body is not all that difficult or take it to a well established TRANS SHOP. See if this will help - https://cogpro.com/chapters/K-TwoSpe...atic/index.htm
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 11-29-2023 at 06:46 PM. Reason: THE USUAL |
11-30-2023, 09:43 AM | #4 |
Re: 64 falcon
No, this is not the tranny I have. These pictures show a seal on the shaft, and I have an o ring.
11-30-2023, 10:04 AM | #5 | |
Re: 64 falcon
The heading reads F/M/2 but then describes a TORQUE-FLITE or Section M - Three Speed Hydramatic/M - 3 spd My mistake for not proof reading ... You can buy on CD the SHOP MANUAL, the MASTER PARTS CATALOG and usually the TRANS SHOP MANUAL. Nice to have ...
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
11-30-2023, 12:44 PM | #6 |
Re: 64 falcon
thanks al |
11-30-2023, 05:11 PM | #7 |
Re: 64 falcon
Guess I should have given you a lead ...
This is what you are looking for ... The CD for the FALCON does not show including the TRANS WSM - https://www.detroitironis.com/ You should be able to find a paper copy on FleaBay. If not, get back.
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 11-30-2023 at 05:27 PM. |
11-30-2023, 05:26 PM | #8 | |
Re: 64 falcon
Guess many of these older sites are not kept up. |
