Old 09-27-2023, 11:53 AM   #1
busmania
busmania's Avatar
Default Stripped oil pan nut
The far rear but on my oil pan seems to be stripped. Back by the starter. Can I make this oversize with the pan on? What is the next size up? Photo below.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/
busmania is offline   Reply With Quote
Old 09-27-2023, 11:55 AM   #2
J Franklin
J Franklin's Avatar
Default Re: Stripped oil pan nut
Use a thread repair insert.
Old 09-27-2023, 01:46 PM   #3
Jack E/NJ
Jack E/NJ's Avatar
Repair it the easy way. Different sizes are available.
Jack E/NJ is offline   Reply With Quote
Old 09-27-2023, 01:51 PM   #4
kurt v
are you sure that the front and rear two aren't larger than the others.
kurt v is offline   Reply With Quote
Old 09-27-2023, 01:53 PM   #5
busmania
busmania's Avatar
Not sure. I wondered this too. But all of the other ones torqued just fine. I could t even get this one snug.
Old 09-27-2023, 03:58 PM   #6
Karl Wolf
Karl Wolf's Avatar
I think that I would remove the oil pan, weld up the hole.
Drill and tap new threads. Be sure to get the location correct.
I just looked at a spare, to hard to put a nut inside.
And I hesitate to go oversize.
Karl
Karl Wolf is offline   Reply With Quote
Old 09-27-2023, 05:23 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
Possibly take out the starter and use longer bolt and a nut
Old 09-27-2023, 05:24 PM   #8
J Franklin
J Franklin's Avatar
Helicoil
Old 09-27-2023, 06:49 PM   #9
busmania
busmania's Avatar
Ok so I ran a tap through it (original size) and then I was able to torque it. Not sure it will hold but we’ll see. Normally I’d take the pan off and tap it correctly, but I already took the pan off once for another screw up and dont want to do it again unless I absolutely have to…which I’m sure at some point I’ll need to do at that point I’ll repair correctly next time it’s off. The first time I torqued the pan down it torqued down fine so this is somewhat strange. I tried two different bolts that wouldn’t torque until I ran the tap through.
