09-09-2023, 04:30 PM | #1 |
Pair of 97's set up to be secondaries
City:
Kerrville
State:
Texas
Price:
$250 pr.
These 97's were modified to be used as secondaries in a 3x2 set up. All the choke parts were removed. The throttle stops were secured to the base so the throttles could be adjusted open a little. They have been completely disassembled, inspected, cleaned, and reassembled. New kits were installed. The bleed jets, emulsion tubes, jets are all fine and stock. The idle circuits are complete and have new screws. The accelerator circuits were tested and the nozzles flow fine. The top screws were replaced with stainless ones and empty holes plugged with stainless set screws. Bases and linkages were painted. Everything moves fine. One lid has a filled hole from a SouthWind heater installation. It is hard to see.
10-19-2023, 09:54 AM | #2 |
Re: Pair of 97's set up to be secondaries
I can put together a matching center carb to complete a 3x2 set up if interested. Same quality. |
