Old 07-24-2023, 09:24 PM   #1
Dirtslinger
Default 8BA tight main bearing clearance
Im having some trouble with getting proper bearing clearance. I managed to buy a NOS Mercury 4" crankshaft along with King Standard bearings. Now Im getting a .001-.0015 clearance on the rear main using plastiguage. Using a mic and bore gauge, Im getting a clearance of over .003. The block has not been line bored. Im going to have a friend come help with a second measurement to make sure its not my tools. Looking for some help and ideas to get this thing together.
Dirtslinger is online now   Reply With Quote
Old 07-24-2023, 10:37 PM   #2
cadillac512
cadillac512's Avatar
Default Re: 8BA tight main bearing clearance
Plastigage does have its place, but a dial bore gauge and micrometer trumps it for accuracy. You can also set up a dial indicator gauge above the rear crank flange then pry upward to see how much the crank moves with rear bearing in and torqued. That will tell the tale.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 07-25-2023, 07:43 AM   #3
pistonbroke
Just for the record, the bearings and crank are dry as in no lube right?
pistonbroke is offline   Reply With Quote
Old 07-25-2023, 02:46 PM   #4
Dirtslinger
I did have lube on the top of the journals to hold the plastiguage. The thrust clearance does seem to be on the tighter side also. I originally have purchased a used merc crank that ended up having a very sloppy thrust clearance, the latest crank is Nos.
Old 07-25-2023, 04:49 PM   #5
Karl Wolf
Karl Wolf's Avatar
I use brass shim stock and a micrometer to measure clearances.
Start by putting the crank in the block, lube, torque the mains, see if it move freely.
Check end play with feeler gauges.
Pull one cap at a time, and put in shim stock, When tightening be careful to look for when crank is hard to turn. Put in more or less to find true clearance.
Look for .001- .003". I like right in the center, .002"
Can be done with paper.
And- no I don't like Plastigauge.
Karl
Karl Wolf is offline   Reply With Quote
Old 07-26-2023, 08:37 PM   #6
Dirtslinger
Karl wolf, I am going to order some of those shim stack. Question is: although the manual states that clearance can be from .001-.003, would anyone run the rear main with that tight of a clearance? The front main is coming in around .0025. The middle is also on the tight side at .0015. Im starting to believe that the block needs to be line bored. Unfortunately I already have the valve train in and lashes set.
Old 07-27-2023, 06:05 AM   #7
Bored&Stroked
Bored&Stroked's Avatar
I always setup my flathead cranks for about .0025 clearance on all three. If anything, I try to have a bit more on the rear main - .00275 - due to the rear of the crank potentially getting hotter (due to the clutch) - and expanding a bit. The challenge is that sometimes the bearing shells are not perfect - I've had to swap sets around in some cases to "tune" the clearance a bit.
New or Regrinds: I purposely have my cranks ground for the clearance I want - and always have my bearings/block in hand and measured before grinding.
Do you have access to good mics and a 3-point dial bore gauge - and somebody who knows how to use them? If not, the shim stock method will work as well - and you don't have to rely on mics that you don't know.
As others noted - I wouldn't trust plastigauge to determine my final bearing clearances. It is fine for a "quick check" (which you've done), but don't rely on it for understanding whether you're a thou or two off.
Old 07-27-2023, 11:08 PM   #8
Dirtslinger
If I’m .001 too tight on a main, could I use one half of a .002 bearing to get that extra .001? Just a thought.
Old 07-28-2023, 06:16 AM   #9
Bored&Stroked
Disregard my prior "half-shell" babble . . . I was temporarily insane! LOL
This still stands: First of all, I'd have the align-bore and clearances checked by a competent machine shop (with the right mics) . . . you may be chasing the wrong beast.
Are you sure this block came with the main caps you're using?
D
Old 07-28-2023, 07:52 AM   #10
Ol' Ron
Ol' Ron's Avatar
I have several boxes of used bearings I use to get the clearance I want.
G
Old 07-28-2023, 11:17 AM   #11
Ronnieroadster
Ronnieroadster's Avatar
I believe you would be going in the wrong direction from what your trying to do.
The.002 bearing would not be a larger diameter its a tighter diameter used to tighten up the clearance on a slightly worn journal.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 07-28-2023, 11:27 AM   #12
cadillac512
Ronnieroadster
Exactly.
Old 07-28-2023, 01:22 PM   #13
marko39
I’m following this as I have the same situation. I had block and mains checked and honed. Front and center are good and rear measures.001. My machinist said it was within spec. but he likes to see .002 min. He said I could try another rear bearing or “ massage “ the bearing. After reading ole Ron’s post I’m thinking that might be worth trying.
marko39 is offline   Reply With Quote
Old 07-28-2023, 02:32 PM   #14
Bored&Stroked
Yep - I had my head on backwards on that one! I've half-shelled a .010 crank with a .009 bearing . . . which gives more clearance. Trying to half-shell a STD crank with a .002 bearing gives .002 LESS clearance.
Thanks Ronnie and crew . . . I should have drunk more coffee before I babbled! LOL
Old 07-28-2023, 11:05 PM   #15
Dirtslinger
Haha, yes I was going in the wrong direction. I do have my original bearings and they do look ok, I’ll have to try them out. They’re both standard, I could use one older bearing and the other the new one if that makes for better clearances?
Old 07-29-2023, 02:32 PM   #16
Flathead
Flathead's Avatar
Wouldn't half of a std. and half of a .002 give you .001 tighter clearance?
Flathead is offline   Reply With Quote
Old 07-29-2023, 07:22 PM   #17
Bored&Stroked
Yep . . . that is why I was temporarily out of my mind!
Old 07-29-2023, 11:07 PM   #18
Ol' Ron
Ol' Ron's Avatar
I try to use the complet bearing to get the proper clearance. However I see no reason why 1/2 beraing shel wouldn't work. (.001/.0015) is not really OUT OF ROUND, is it????
G
Old 07-30-2023, 09:55 AM   #19
Bored&Stroked
G
Yeah, I was thinking the same thing, but forgot that I've not had any bearings designed for a crank that was .001/.002 OVERSIZE . . . as that is what you'd need. All the .002 bearings we see are for journals that are worn and where a .002 tighter diameter bearing might help. This means the bearing is taking up clearance, not giving some back (which is what he was talking about).
You can purchase racing bearings for some modern engines that are for .009 instead of .010 journal sizes - this is how we 1/2 shell some of our engines (Think BBC cranks).
Anyway, this engine block, mains and crank just need to be accurately checked out - to first of all identify what the problem is. My best guess is that the mains are not right. Could be an alignment problem, could be the caps, could be the bearings themselves, could be the crank . . . or some combination of all these things.
