Old 10-26-2023, 12:17 AM   #1
1930artdeco
1930artdeco's Avatar
Default Mello Tones on a Y block
This what her new exh. system sounds like. Nice little rumble when I get her dialed in.
https://youtube.com/shorts/aDW2ewwu2...eyRpoedEHvTrB-
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-26-2023, 06:46 PM   #2
miker98038
miker98038's Avatar
Default Re: Mello Tones on a Y block
Sounds good. Glad to see you’re making progress.
miker98038 is offline   Reply With Quote
Old 10-26-2023, 08:50 PM   #3
55blacktie
What mufflers did you use? Size? How loud when you're on it?
55blacktie is offline   Reply With Quote
Old 10-27-2023, 12:08 PM   #4
1930artdeco
Just bought Mello Tones-22" (the longest ones) as I didn't want the crackly sound of the short ones. Just on idle for now, I will post a second video when I get the engine sorted out.
1957 Country Sedan
Old 10-27-2023, 05:46 PM   #5
Gene F
Gene F's Avatar
My streetrod has Flowmasters, and it seems too loud for me. The car has a 373:1 gear, so maybe that has something to do with it. My last streetrod had Cherry Bombs on it, which were not too bad. I put a set of MagnaFlows on my 57 Skyliner with a Y-block. Pretty normal sounding...untill you take off from a light and floor it. Then you get that Y-block sound I have always heard about. Took my Dad for a ride, and he sure noticed! I'd buy MagnaFlow again!
Old 10-27-2023, 06:14 PM   #6
55blacktie
Good to know, Gene. I bought Borla ProXS mufflers for my 55 Tbird, but not yet installed. I think they're very similar to the Magnaflows. I wanted straight-through mufflers without all of the noise. I don't think it needs to be loud to sound good.
What size are your Magnaflows?
Old 10-27-2023, 07:06 PM   #7
Gene F
Gene F's Avatar
The physical size is the same as factory. Factory size pipe too. Factory exhaust manifolds.
Borla - I always like those. Especially with the large tubes. But the price!!!!
Old 10-27-2023, 08:43 PM   #8
55blacktie
Space is limited on my 55 Tbird; the Borlas are pretty close to the same size as OEM, but 2 1/4 in and out vs. 2 in and 1 3/4 out for OEM. I also bought their resonators, which were actually more expensive than the mufflers. The resonators, in theory, deepen the tone and reduce/eliminate drone. Although 56-57 Tbird resonators are located towards the rear, after the mufflers, most recommend putting resonators before the mufflers.
Old 10-28-2023, 09:24 AM   #9
Ford56
Ford56's Avatar
I've had Flowmasters and others, and they've been good, but I love the sound of the Mello Tones.
Ford56 is offline   Reply With Quote
Old 10-28-2023, 11:16 AM   #10
Hot Rod Reverend
Hot Rod Reverend's Avatar
https://youtube.com/shorts/oxf2KFW0X...xtNYpo4zvMtR-l
I have the same set of glass packs that I installed way back in 1992. I love the sound, but I know they are not the greatest on performance. Back then I also replaced the rear pipes - believe they are 1.75" exit. Everything is still as solid as it can be, but with my upgrade to a a set of true headers last year I do want to increase the flow and size of the pipes. I did buy a set of Summit's performance mufflers but I believe they are a Flowmasters copy. I would like to go with at least a 2" pipe out the rear.
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 11-07-2023, 03:41 AM   #11
Grumpy Rick
Back in the day, we always put a balance tube between the two pipes, ahead of the mufflers. It made the Y-block sound much smoother. Product of the firing order I guess, as they always sound like the spark is retarded without the tube.
I like 36" glasspacks, as Flowmasters sound like a trash truck to me. I will be removing them from my 55 T-Bird.
YMMV
Grumpy Rick is offline   Reply With Quote
Old 11-07-2023, 05:24 PM   #12
55blacktie
I have considered putting an H-pipe on my 55 Tbird for that reason. I've been communicating with an owner of a 57 E-code Tbird who did the same. Ted Eaton, however, said that neither an H nor X-pipe will increase Y-block performance.
Most Flowmasters that I've heard on vehicles without cats have a metallic sound, similar to marbles rattling inside a tin can.
Old 11-17-2023, 11:57 AM   #13
Abe Lugo
Sounds good, I think my wagon has the same, but very old ones. Those sound new and crispy, Idle sounds good too.
FYI I think there is an image on wagon exhaust routing for the tips. There a certain angle and length, which you can do with the chrome extension, so exhaust doesnt come into the cabin if the rear window is up .
Abe Lugo is offline   Reply With Quote
Old 11-17-2023, 12:25 PM   #14
1930artdeco
Yep, I had him replicate the location of the original single exhaust. I will put angled tips on eventually. Dress her up a bit. But right now I am doing floor pans.
1957 Country Sedan
Old 11-17-2023, 05:23 PM   #15
KULTULZ
KULTULZ's Avatar
Yes, they do -
https://www.motortrend.com/how-to/x-...for-your-ride/
KULTULZ is offline   Reply With Quote
Old 11-17-2023, 05:25 PM   #16
KULTULZ
KULTULZ's Avatar
Arrow Re: Mello Tones on a Y block
If the window is up or down. Carbon monoxide collects at the rear of the car in motion and will enter the cabin.
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
