Old 06-01-2010, 09:55 PM   #1
34fivewindow
34fivewindow's Avatar
Default 35-36 pickup rubber floor mat
Has anyone found a good supplier for 35-36 pickup black rubber floor mats?......Thanks....Ed
34fivewindow is offline   Reply With Quote
Old 06-02-2010, 07:47 AM   #2
Newaygo Kid
Default Re: 35-36 pickup rubber floor mat
I bought one from Dick Spardo a few years ago I think it was one for a 39. It was not quite the correct one but it was the closest one I could find it looks good. I had to trim just a little on the sides and the back where it butts against the seat riser, good luck Chris
Newaygo Kid is offline   Reply With Quote
Old 06-02-2010, 08:15 AM   #3
36tbird
I went to my local upholstery supply and they had some ribbed rubber matting on big rolls. The other side of the ribbing has a good floor mat type texture. You might check with you local store to see if that can work for you.
36tbird is offline   Reply With Quote
Old 06-02-2010, 08:45 AM   #4
Brendan
Brendan's Avatar
would one from a 36 car work?
Brendan is offline   Reply With Quote
Old 06-02-2010, 01:07 PM   #5
jerry grayson
No on the 36 car mat. No one is making the correct mat for the 35 or 36 pickup(they are different). I think that one may still be available for the 40 truck and you can cobble up one out of this. Too bad that they are not available!!
jerry grayson is offline   Reply With Quote
Old 06-14-2010, 12:15 AM   #6
Jed
they don,t make one
Jed is offline   Reply With Quote
