09-26-2017, 10:48 PM | #1 |
'40 restored 6V radio convert to 12v system
hi guys--want to get the BEST converter @ a fare price. WHAT do i use ? THANKS for any help ! Bruce @ (410) 456 3784 C [email protected]
09-27-2017, 12:23 AM | #2 |
Re: '40 restored 6V radio convert to 12v system
If you are talking about a high amp voltage reducer, that's just one of the parts of the puzzle. The vibrator in the radio may or may not be compatible with a reverse polarity 12 volt system. (not positive ground any more)
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 09-27-2017 at 12:29 AM. |
09-27-2017, 06:51 AM | #3 |
Thanks for the info ! Bruce
09-27-2017, 09:25 AM | #4 |
If you have experience working with electronics, change the tubes to 12v, i.e. 6v6 becomes 12v6, 6SJ7 becomes 12SJ7 etc. and the B+ is modified to reduce voltage to between 100v and 120v. Change vibrator to solid state. Most radios will work on negative ground 12v with these changes. Sams are available if you can deduce the manufacturer and model number.
The $525 route is also available where your radios is gutted of it's electronics and a tiny AM-FM boards is substituted with many features including Bluetooth for your cell. These have widely positive reviews. |
09-27-2017, 02:37 PM | #5 |
THANKS Paul & who to contact for $525 radio ! Bruce
09-27-2017, 03:05 PM | #6 |
http://www.turnswitch.com/radio1.htm
09-28-2017, 12:37 PM | #7 |
Charles Forgey of Harrision TN can do what you need including changing it to AM-FM
Ph: 423-344-8357 or 423-785-6333 www.OldCarRadio.net |
09-28-2017, 01:53 PM | #8 | |
41 woodie https://41fordwoodie.weebly.com/ |
