Old 05-25-2017, 06:36 PM   #1
joe plumber
Default New Edelbrock 94
Anyone heard anything about the 94 Edelbrock carb,good ,bad or otherwise
joe plumber is offline   Reply With Quote
Old 05-25-2017, 07:19 PM   #2
baldmustang
Default Re: New Edelbrock 94
I put one on my 51 F1 flathead. Started up easy, runs great. Very Happy. Did not have to adjust. I bought it from Midwest. It was expensive $324.00
Unfortunately, I don't get to drive it much. Probably ran two tanks of gas through it so far.
baldmustang is offline   Reply With Quote
Old 05-25-2017, 07:39 PM   #3
joe plumber
The cheapest I have found so far is a a little over$400
Old 05-26-2017, 08:35 AM   #4
Ole Don
Ole Don's Avatar
Anything Edelbrock will be good. The name is on the part. The four barrels come with a book on how to tune, read it.
Ole Don is offline   Reply With Quote
Old 05-26-2017, 08:08 PM   #5
TedEaton
TedEaton's Avatar
I put a trio of them on a warmed over 272 Y-Block. Due to camshaft being a bit on the wild side, the idle feed restrictions in each carb had to be reduced in size. Here's the link to the article that was published in Y-Block Magazine which goes into more detail on the modifications performed to the Edelbrock 94 carbs.
http://www.eatonbalancing.com/2015/0...ng-up-the-272/
Ted Eaton.
TedEaton is offline   Reply With Quote
