Old 07-26-2016, 04:24 PM   #1
Ron Lachniet
Ron Lachniet's Avatar
Default Transmision Tower tool
I was at a consignment shop today and saw what looked to be a tool that would compress the spring on a model a transmission shift tower. It had an upper and lower set of fingers that would separate with a turn knob on top and was about 1.5 in. in diameter. If such a tool was made I would like to see a picture of it.
Ron Lachniet is offline   Reply With Quote
Old 07-27-2016, 03:43 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Transmision Tower tool
do you have a picture of the one you saw?
Old 07-27-2016, 06:22 AM   #3
Ron Lachniet
I did not get a picture of it, but it is not a valve tool. The fingers that capture the spring are in line with the knob that compresses the spring. The knob is about 4 inches in diameter and maybe too small for the amount of tension on the tower spring. It also looks like it has about an inch and a half and that may not be enough travel. It is stamped K-R.
