05-22-2016, 07:20 AM | #1 |
Need Confirmation On Head Gasket Placement...
Copper type head gasket. Does the raised crimped edge side go towards the block and flat side go towards the head? thanks...
05-22-2016, 07:33 AM | #2 |
Re: Need Confirmation On Head Gasket Placement...
The larger water hole goes to the rear. The smaller water hole goes at the front. The crimp location is not important.
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
05-22-2016, 07:44 AM | #3 |
The crimp goes to the head. There is always a slight amount of movement between the head and block which will etch the gasket into the cast. It is easier to re-surface the head than the block to get rid of this.
http://www.model-a-ford-4bangers.com/ |
05-22-2016, 09:20 AM | #4 |
Crimp side up. As James said above.
05-22-2016, 09:47 AM | #5 |
Go with posts 3 & 4....
05-22-2016, 11:59 AM | #6 |
05-22-2016, 04:55 PM | #7 |
Mr. Rogers is an expert, follow his advice and you can never go wrong! Wayne
