Old 09-12-2014, 03:13 PM   #1
dlfrisch
dlfrisch's Avatar
Default Fuel Gauge Project
Any unforeseen tricks to installing a new gas gauge assembly? My existing gauge is stuck on 1/4, the glass face is blacken out quite a bit and probably the float is either off or just missing.
dlfrisch is offline   Reply With Quote
Old 09-12-2014, 03:15 PM   #2
Tiny
Tiny's Avatar
Default Re: Fuel Gauge Project
Rebuild the old one. Its not hard and quite a bit cheaper. Use cork gaskets for the glass and a neoprene float. It does take a special tool to do the job
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 09-12-2014, 05:39 PM   #3
1931 flamingo
1931 flamingo's Avatar
Disconnect the battery BEFORE you start ! ! !
paul in CT
Old 09-12-2014, 06:04 PM   #4
Allanw
Allanw's Avatar
paul in CT
VERY good idea!
Also, another NZ member somewhere said to use maple syrup on the seals It actually works well - I used it on ours, and it stopped a very light weep we had. Because it doesn't disslove in the fuel, it dries in any tiny gaps in/around the seals.
Allan
'29 Tudor, Canadian RHD
Whangarei, NZ
"Duct Tape can't fix stupid, but it can MUFFLE the sound"
Allanw is offline   Reply With Quote
Old 09-12-2014, 06:13 PM   #5
Mitch//pa
make sure the fuel tank level is below the opening
the front of the car should not be on an uphill steep incline
wear your depends just in case
Old 09-12-2014, 06:17 PM   #6
Ron in Quincy
Ron in Quincy's Avatar
You can get the neoprene float from Bert's in Denver. As others have said, use cork gaskets. I personally put a thin film of Napa Aviation Form-A-Gasket Sealant on the inside of each cork gasket as it is gas resistant, even to the new gas, and assures of no leaks.
Ron
Ron in Quincy is offline   Reply With Quote
Old 09-12-2014, 06:54 PM   #7
dlfrisch
dlfrisch's Avatar
Thanks for the tips (even though it wasn't money). I'll probably work on the fuel gauge this weekend. It's supposed to rain and we can't ride our Harely's, unless we want to get wet.
While I have the dash apart, I have to see what may be the problem with my speedometer. It pop the MPH numbers up and down. Maybe a bad gear on the drive ???
Old 09-12-2014, 08:07 PM   #8
Tom Endy
Tom Endy's Avatar
I would recommend a brass float. You can get one at a very reasonable price from the fellow in San Diego that makes them. Reenlee H. Kotas 858-278-8178.
You will also need the two tools that come as a set to remove the gauge. Most all the Model A suppliers carry them.
Clean the area around the gauge thoroughly, but do not use a vacuum cleaner as it will suck gas fumes into the sparking vacuum motor.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 09-12-2014, 11:02 PM   #9
Smog Tech
Smog Tech's Avatar
I agree with Tom, the brass float should work with whatever they decide to put in gasoline in the future. Also available from Mikes-afordable.
Smog Tech is offline   Reply With Quote
Old 09-12-2014, 11:10 PM   #10
Bob from Northport
Bob from Northport's Avatar
Tom is right. The brass floats are great!! Have used several. Get them from the California seller.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 09-12-2014, 11:14 PM   #11
Mike V. Florida
Mike V. Florida's Avatar
Multiple thin brass washers will help in keeping the center section from spinning.
Old 09-13-2014, 06:40 AM   #12
KGBnut
KGBnut's Avatar
It can be hard to get the original gauge apart to rebuild it. I soaked mine in lacquer thinner for about a week to free everything up.
Absolutely worth rebuilding the original. I've never found a reproduction that I was happy with. The rebuild is an easy job.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 09-13-2014, 07:22 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
I pull the float lever pin and remove the arm, then slip the U shape over a piece of 3/4" plywood clamped in the vice. Now I can really press down as I turn the inner nut off. I also soak it with Kroil, as some are VERY stuck.
Old 09-14-2014, 04:20 AM   #14
nickair
nickair's Avatar
When installing just test fit it first as you may need to bend the float wire to calibrate it. Remove the fuel fill screen and use another wire bent as a hook to grab the float wire and gently pull it to yhe top of the tank. It should read full. This will give near one gallon left when it reads empty. Bend the float wire about one inch from the pivot to adjust it. The others said the rest. It is an easy job.
Simplicity is the ultimate sophistication.
L.D.
I have 40 horses in the garage.
Only feed them when I want to take them out.
31 Model A Tudor 55B
Nick
nickair is offline   Reply With Quote
Old 09-14-2014, 07:42 AM   #15
rocket1
The early A's had a magnifying lens in the gas gauge,the rebuild kits have a flat glass,it's advantages to clean up that glass with the bubble.
rocket1 is offline   Reply With Quote
