Old 09-01-2014, 08:45 AM   #1
Gold Digger
Default Thermoquail
Does anyone besides me have trouble with their thermoquail turning side ways and falling open while driving? I have bought new rubber rings and that don't help for over 4 hours running time. The last thing I've done is cut out a plastic shim to go under the rubber. Just wondering what everyone else does.
Gold Digger is offline   Reply With Quote
Old 09-01-2014, 10:07 AM   #2
Jynx
Default Re: Thermoquail
Just started with mine
Jynx is offline   Reply With Quote
Old 09-01-2014, 10:58 AM   #3
sidhartha
sidhartha's Avatar
I have one with the same problem. Shimming it is the only solution I've found.
sidhartha is offline   Reply With Quote
Old 09-01-2014, 12:55 PM   #4
pooch
pooch's Avatar
I have 2 thermo quails on 2 cars and never had a problem.
Just a word of caution, to open and close, grab the bird by the head and top of back only.
If you grab it naturally you will find your fingers around and under and the thermometer breaks easily.
Never let anyone else touch the bird .
pooch is offline   Reply With Quote
Old 09-01-2014, 01:43 PM   #5
nickair
nickair's Avatar
Last week I had a friend stop by with his 29 coupe. He has the same problem with his quail cap. It is loose at gasket fit and rotates an inch or so as he drives.
Looking for a solution with a better fitting gasket, or is it an install issue?? His gasket causes a loose fit when securing the quail.
Simplicity is the ultimate sophistication.
L.D.
I have 40 horses in the garage.
Only feed them when I want to take them out.
31 Model A Tudor 55B
Nick
nickair is offline   Reply With Quote
Old 09-01-2014, 01:47 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
I gave up on thermoquail caps. The two that I used never registered and they are famous for ruining the radiator neck.
Old 09-01-2014, 04:41 PM   #7
stewwolfe
stewwolfe's Avatar
My thermoquail has never vibrated open. I would look at the gaskets first.
'31 40B
'31 68C
stewwolfe is offline   Reply With Quote
Old 09-01-2014, 05:30 PM   #8
mshmodela
mshmodela's Avatar
I had to cut my own upper gasket... The lower one, which is hidden worked fine but the upper was useless --too thin. I got a few rubber washer from Sears hardware and cut my own... It took more playing with than shown below but works very well... I wanted just the right thickness to hold but not too much to too extra stress on the quail hinge. So far about 3 months and nothing comes out from it... Took a nice 18 mile city drive today in 85F.. all dry bird...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 09-01-2014, 06:16 PM   #9
Ron W
Ron W's Avatar
I bought a O-ring about 3.5 X 48 MM. No more problems. Ron W
Ron W is offline   Reply With Quote
Old 09-01-2014, 11:57 PM   #10
huddy
huddy's Avatar
Found them on Amazon, but I imagine they're widely available:
O ring 3.5x48 mm
Owning an antique car is "start fixing one thing, find four other things that need fixing." Lather, rinse, repeat.
huddy is offline   Reply With Quote
Old 09-02-2014, 01:45 AM   #11
tbirdtbird
O-ring is great idea.
I have used a couple brass gas gauge shims under the rubber that was supplied....same diam.
'31 180A
tbirdtbird is offline   Reply With Quote
Old 09-02-2014, 02:59 AM   #12
nickair
nickair's Avatar
Just ordered the suggested
Fluorine Rubber O Ring Oil Sealing Gaskets 48mm x 3.5mm
Will report back when installed on my friend's A.
L.D.
Nick
Old 09-02-2014, 06:16 AM   #13
Ron W
Ron W's Avatar
I got mine at the local hardware store. Ron W
Old 09-02-2014, 07:00 AM   #14
CountrySquire55
CountrySquire55's Avatar
I bought some #223 E70 O-rings from the O-Ring Store online. Cost is $.18 each. Costs more to ship! One O-ring works perfectly in my thermoquail.
CountrySquire55 is offline   Reply With Quote
