06-28-2013, 05:31 PM | #1 |
32 Battery Pan Dimensions?
Can someone provide me with the dimensions for the battery pan(sheet metal portion) of the 32 battery holder? I need to make a new one as mine is rotted out.
It does not matter weather it is the version with the rock shield or not. Thanks, Keep V-8ing and 4-banging!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
06-28-2013, 08:43 PM | #2 |
Re: 32 Battery Pan Dimensions?
Why make one when they are available for $30 reproduction?
Short URL: http://smu.gs/14g7eDW |
06-28-2013, 10:21 PM | #3 |
Jim,
Making the parts is part of the fun I do like the challenge of making things with a limited shop. Keep 4-banging!
06-29-2013, 07:17 PM | #4 |
if I get out to my car this week I will send you the measurements. I have a repop one. the one in the car had a piece of plywood to support the battery.....not quite as henry made it
06-29-2013, 09:17 PM | #5 |
Thanks, I have two brackets, one that came with the wagon and one that I picked up. So I figured I'd make a pan. Should be pretty straight forward bends and hammer form the drain channel. Keep 4-banging!
