Old 12-10-2023, 06:51 PM   #1
ahshoe
Default Update to a 4-speed on my ‘56 F100
Got a nice running 292 Y block in my ‘56 F100. Has a stock 56 truck 3 speed in it that came with the truck I am sure from the factory. It had a brand new Maverick 8” housing with a new 3:25 traction loc. I would like to use a newer 4-speed so I can run over 55 on the highway.The bellhousing has the rear frame mounts as part of it and the clutch Zbar pivots off it also.Has anyone converted to a different bell ,and 4 speed trans.and if so what problems am I going to (or did they run into) doing so and maybe converting to a T-10 or toploader 4 speed? Any information would be appreciated. Might want to add that I already switched the three on the tree to a floor shifter.
ahshoe is offline   Reply With Quote
Old 12-10-2023, 08:03 PM   #2
51504bat
51504bat's Avatar
Default Re: Update to a 4-speed on my ‘56 F100
Both a T-10 4 speed or a 4 speed toploader have a final ratio of 1:1 the same as the 3 speed you have. So changing to either of the 4 speed trans you mention won't lower your cruising RPM. A T-5 or a 3+1 from a Ford p/u would do what you want since both are overdrive transmissions.
Old 12-10-2023, 09:30 PM   #3
Gene F
Gene F's Avatar
So I have a 292 in a Fairlane. You can buy a new T-5 from jegs. So what is involved in converting to a sitck from an automatic in a 57 Fairlane?
Gene F is offline   Reply With Quote
Old 12-11-2023, 12:05 AM   #4
miker98038
miker98038's Avatar
Biggest thing is the clutch linkage. There might be enough 57’s out there with modern engines and AOD’s (or whatever) to find the whole works. Then a car bellhousing, an adaptor, the the right T-5. Years ago when I did the bird the adapter required cutting about 1/8” off the T-5 WC so it didn’t bottom in the crank. That was not a big deal.
I used a Mustang trans mount, pretty much bolted up in the bird. Don’t know about a 57 pass car.
Do your research on the T5. There’s a lot of different ratios, torque ratings, and shifter placements. If someone here doesn’t have specifics, I’m sure one of the other Ford sites or social groups will.
miker98038 is offline   Reply With Quote
Old 12-11-2023, 04:10 AM   #5
KULTULZ
KULTULZ's Avatar
Post Re: Update to a 4-speed on my ‘56 F100
Are you wanting to keep it three-on-the-tree or modify the truck?
Because of the way the engine/trans is mounted, maybe consider a period correct 3/S/OD?
- https://www.ford-trucks.com/forums/index.php
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 12-17-2023, 06:08 AM   #6
flathead 53
I installed A S-10 five speed in my 53 f-100 with A mercury flathead , 60 mph 1800 rpm, I also installed A 9"rear from A 59 f-100 with 350.1 gears , I kept the original bellhousing,
flathead 53 is offline   Reply With Quote
Old 12-17-2023, 06:11 AM   #7
flathead 53
I also used original clutch linkage ,PM me for more info on this ,
Old 12-17-2023, 09:42 AM   #8
38 coupe
38 coupe's Avatar
Assuming you have 28 inch tall rear tires your engine is turning less than 2200 rpm at 55 mph. A 292 should happily turn way more revs than that. I find 2700 rpm to be a comfortable cruising rpm and that calculates with your axle ratio to about 70 mph. Your rpm will scale up or down inversely with tire diameter compared to the 28 inches I used to calculate this.
