Old 11-08-2023, 12:00 AM   #1
SoCal32
Default Best Practical Upgrades to Stock 47 Sedan?
I just picked up a '47 Fordor that was a body-off restoration. Wasn't looking for one but the deal was too good to pass up. Since it will be driven in SoCal traffic and not country roads, what would be the best upgrades? Not looking to change drivetrain, it has a Columbia rearend so the overdrive is handled.
SoCal32 is offline   Reply With Quote
Old 11-08-2023, 12:05 AM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Best Practical Upgrades to Stock 47 Sedan?
Travel the country roads. So much more enjoyable.
Ken/Alabama is offline   Reply With Quote
Old 11-08-2023, 12:28 AM   #3
SoCalCoupe
SoCalCoupe's Avatar
I live in SoCal too. It's hard to avoid the Blue Shield interstate. Thought about your question a lot. You're nearly there with the Columbia.
High reliability is everything. Electrically I'd go stock ignition with a Tubman condensor and Skip Haney coil. Fuel, I'd have a professionally rebuilt carb, surfaces and throttle shafts machined to close tolerances.
Go with radial tires. I love my Diamond Back Auburn radials; it's like the car's on railroad tracks. As far as I know they're super premium, the best available at any price.
Brakes: mine are stock but I've heard great things about Lincoln brake conversions.
Do high reliability ignition, carb, tires and brakes. You're good with the Columbia.
SoCalCoupe is offline   Reply With Quote
Old 11-08-2023, 01:34 PM   #4
SoCal32
Thanks, SoCalCoupe. Speedway actually just released self-energizing drum brakes that bolt on and use the stock drums as an alternative to the Lincolns. May look into those a little deeper.
Old 11-08-2023, 01:39 PM   #5
Darrell S
Darrell S's Avatar
Poor rearview visibility and huge blind spots make heavy freeway traffic challenging. I know how people drive on freeways in my neck of the woods, I don't think yours are much different. Good brakes and steering would be high on the list too. Since you are already driving a 32 you are probably aware of these things. Enjoy the 47.
Darrell S is offline   Reply With Quote
Old 11-08-2023, 07:28 PM   #6
51woodie
51woodie's Avatar
If you do the brakes, go with Bolling Brothers kits. I put them on my ‘46 Coupe, and they were an easy install. Their website has some good info.
51woodie is offline   Reply With Quote
Old 11-09-2023, 01:23 AM   #7
GB SISSON
GB SISSON's Avatar
How about Bright LED brake lights, or even a magnetic LED Third tail light up high along with them.. Now I'm wondering if you have directionals wired up too.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 11-09-2023, 01:41 AM   #8
ford38v8
ford38v8's Avatar
Keep a current EFV8CA Roster in the glove box.
Alan
Old 11-09-2023, 09:31 AM   #9
pistonbroke
Hey Darrell. They do drive the same because they are Californians!
pistonbroke is offline   Reply With Quote
Old 11-09-2023, 10:26 AM   #10
wga
wga's Avatar
Stock brakes on my 49 are great at stopping one or two times on the freeway. It is the brake fade that concerns me. I live in North Orange County and getting out on the freeways takes planning. If I drive north its I5 to 101 and that means driving into LA county. Not fun, it is always congested.
You need bright turn signal lights for sure. Try LED tail lights. I went to 12V prior to LED for that reason. Also radial tires, I use Coker that were sourced from Summit Racing as they pay the freight with orders > $100.00.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 11-10-2023, 01:13 AM   #11
SoCal32
Thanks, all good suggestions. I was considering 12-volt
Old 11-10-2023, 06:49 AM   #12
38 coupe
38 coupe's Avatar
The only area I consider a stock 1947 Ford to be lacking is tail light brightness. Otherwise a car in good condition with good tires and a good tune up is good to go, no need for modifications.
Old 11-10-2023, 02:11 PM   #13
Charlie Stephens
Add safety hubs (or clips) for the brakes. Add turn signals and a second brake light if they are not there already. Check the date code on your tires.
Charlie Stephens
Old 11-10-2023, 03:32 PM   #14
Seth Swoboda
Seth Swoboda's Avatar
It has a Columbia overdrive, I can't imgaine what more you could want. I can easly do 70 mph in our '47 tudor with a 3.54 rearend and it's comfortable to drive.
Seth Swoboda is offline   Reply With Quote
