08-05-2022, 02:15 AM | #21 |
Re: Oil Chex Gauge
There is a member here that does speedometers.I think his user ID is Papanick? Here is the link to him
https://www.fordbarn.com/forum/member.php?u=21132 |
08-10-2022, 09:14 AM | #22 |
Re: Oil Chex Gauge
By the way, these directions for the oil chex gauge are perfect yesterday I installed my dash and installed the guage and it works great, thanks All
09-20-2022, 10:30 PM | #23 |
Re: Oil Chex Gauge
So a few questions, I installed it successfully, and it works great, as I drove it around for a few weeks. But here are two things that went astray I need some advice for, the first one is: it is getting some condensation or some thing on the inside of the glass while I was driving it? See photo.
The second is, at some point I had to disconnect the battery for a non-related issue, when I reconnected the battery, the on off feature would click on and off as I connected-disconnected the battery, and now when I drive the car it stays in the off position…. Any thoughts? |
09-21-2022, 07:56 AM | #24 |
Re: Oil Chex Gauge
The pressure sender is not working correctly or at all.
09-22-2022, 12:28 AM | #25 |
Re: Oil Chex Gauge
Digger, The reason your gauge is fogging up is because it is getting hot inside which is caused by a high resistance or loose or bad connections on the ammeter connections either inside the gauge case or outside the gauge case. Make sure your ammeter terminal connections are clean and tight. Test the oil gauge by removing the wire from the oil sender terminal and grounding it on the engine block which should move the oil gauge to ON. Take the wire off ground and the gauge should go to OFF. If the gauge does not do this then it is faulty. From my observations the reproduction gauges ammeter only goes to 20 amps charge and discharge whereas the original gauges go to 30 amps. Regards, Kevin.
09-22-2022, 04:44 AM | #26 |
Re: Oil Chex Gauge
Graham |
09-22-2022, 06:43 AM | #27 |
Re: Oil Chex Gauge
09-22-2022, 06:46 AM | #28 |
Re: Oil Chex Gauge
If its a repo Oil Chex the amp meter will not last.A friend had one and after 2 yrs it failed.Maybe they were improved later on.
09-22-2022, 08:16 PM | #29 |
Re: Oil Chex Gauge
Hello K, thank you for the tips, I will check it out this is an original unit
09-24-2022, 11:03 AM | #30 |
Re: Oil Chex Gauge
i have parts i bought from Rudolf Faltermeier. a long time ago. SEE PARTS FOR SALE
09-24-2022, 01:06 PM | #31 |
Re: Oil Chex Gauge
Kevin was spot on with the knowledge! The amp meter wires were very loose, so I tightened them up snug and took it for a test drive and it cured the fogging of the glass. Now regarding the other test you mentioned, should I be doing that with the engine running or not, or does it matter? It’s still doing the symptom where the battery is fully connected the word “ON” appears whether the on off switch is in either position
09-24-2022, 07:42 PM | #32 |
Re: Oil Chex Gauge
The oil ON - OFF indicator gets its power from the ammeter internally. So the car battery needs to be connected but the ignition switch does not need to be ON or the engine running. Did you test the gauge by disconnecting the sender wire off the sender and grounding it and then not grounding it which should rock the gauge to ON & OFF. Regards, Kevin.
