02-09-2018, 08:42 AM | #1 |
Ford flatheads oil gallery tube
I have two ford flatheads I want to start rebuilding here soon both are rusty. And from the looks at of it both will need to be replaced. Does anyone know where I can get a replacement one? Do they make aftermarket? Anyway to make one? Thanks for any advice
02-09-2018, 09:23 AM | #2 |
Re: Ford flatheads oil gallery tube
If you read my book you will see a picture of the tube and explanation of the expanded areas which seal in the block. I am not aware of anyone who sells this individual part. Yes, I could make one and maybe you can too. But, it might be easier to find a good tube in a scrap block. First, however, it would be prudent to be certain what you have is not usable.
02-09-2018, 09:33 AM | #3 | |
Some of those tubes looked downright horrible, but never a single issue. It's not as easy to replace as it looks, it has "knurls" on it in 3 sections, you risk breaking the block when attempting to remove it. Thanks, Gary in N.Y. P.S. Here's a shot of one taken from a junk block, if you look closely you can see the dimensions written on it. The O.D. is .556", the I.D. is .375", this makes for a .090" wall, fairly heavy. Would take a bunch of bad "rusting" to eat through that thickness to the point it would cause any damage!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
02-09-2018, 09:36 AM | #4 | |
Interesting. I always thought it was just some thin walled tubing. Once again, Ford used some quality stuff. |
02-09-2018, 10:20 AM | #5 |
I've run across one block with a hole rusted in the tube. Several with pretty deep pitting that I am leery of.
02-09-2018, 12:34 PM | #6 |
