Old 12-20-2015, 06:54 PM   #1
Walle
Default Column drop parts interchange
Im trying to figure out which parts who interchange in early Ford column drops.
I have noticed that the contact plate, brush and housing interchange between 32-37 Fords and also 37-39 Nash column drops.
The ball, spring and screw are also interchangable through the years. And the 32-35 & 36-48 ignition locks interchange.
The switch lever interchange on 1932 and early 1935.
If i would restore a total bare 32 column drop, is there any application/years that interchange the internal shaft with the steering lock?
Thanks
Walle is offline   Reply With Quote
Old 12-23-2015, 04:51 PM   #2
Walle
Default Re: Column drop parts interchange
Anyone?
Old 12-23-2015, 06:06 PM   #3
deuce lover
deuce lover's Avatar
32 is all alone
deuce lover is offline   Reply With Quote
