12-12-2011, 06:37 PM | #1 |
"Notches In SW Wind Wing Glass"???
Does anyone know what they are for, i got them from Brattons who in turn got them from A&L and was wondering why they had vertical notches cut into the glass. I called Allen and he is trying to do some research to find out why but was wondering if anyone knew??
mark
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
12-12-2011, 06:50 PM | #2 |
Re: "Notches In SW Wind Wing Glass"???
Maybe to "index" into the Fulton clamp in windwing brackets so they wouldn' slip out.
12-12-2011, 09:41 PM | #3 |
Mark, can you post a picture please.
12-13-2011, 12:18 AM | #4 |
12-13-2011, 12:44 AM | #5 |
Great Threat but Here is what i am talking about.. These Vertical notches cut in... these are not at the ends to allow the glass to get close to the door..what are these for if anyone is aware please
12-13-2011, 07:00 AM | #6 |
BTW, isn't REAR VIEW mirror redundant? |
12-13-2011, 10:20 AM | #7 |
msmaron: Mark, why not give A&L a call?? 1-860-693-2620.
Paul in CT |
12-13-2011, 10:21 AM | #8 |
Fits only when using the Windwing Clamps for closed cars (shown in Bratton's page 107)
Also the glass showed above does not fit on the Fulton set from A&L .. Last edited by Joop; 12-13-2011 at 10:42 AM. |
12-13-2011, 01:41 PM | #9 | |
So Joop you are saying that the notches are Hidden when installed on the closed car brackets????
12-13-2011, 01:47 PM | #10 |
OK here is the answer, the "notch" is about a 1/2 inch to deep, it is used to sit on the closed car bracket and allow the glass to move forward toward the slant....
12-13-2011, 01:53 PM | #11 |
That is my recollection.
Bought a set a long time ago but did not install them, sold the brackets but still have the glass. Maybe someone can post some pictures. |
12-14-2011, 09:48 PM | #12 |
Just looked at the brackets again and there is NO raised area in the bracket for the "notch" to sit into...now it is confusing.
