Old 07-23-2022, 04:54 PM   #1
tommyleea
Default 53 parking light socket
Would like to replace or at least remove and clean up my parking light socket. Is this socket pressed in, and does it go in from the front side or the back side? Thanks for any help on the issue. 53 Ford Ranchwagon.
tommyleea is offline   Reply With Quote
Old 08-09-2022, 09:27 AM   #2
tommyleea
Default Re: 53 parking light socket
I finally did get the old socket out of the housing. Ordered and received a new socket. The new socket fits loosely in the housing. Anyone have an idea on how to tighten up the socket? I was thinking of putting some dimples in the housing where the socket slides into. Any other ideas or experiences. Thanks.
Old 08-10-2022, 12:07 PM   #3
Lanny
Lanny's Avatar
I would solder the socket to the housing, so it makes a good ground
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 08-10-2022, 09:45 PM   #4
Newc
Newc's Avatar
Watch you gasket material. The gray sponge ones suck in water! My lights filled up with water! Newc
Old 08-11-2022, 12:43 PM   #5
tommyleea
Great idea..Thanks
Thanks for the heads up...
