Old 07-30-2022, 03:53 PM   #1
metro1
Default Transmission problem
I have a 59 Galaxie with a 2 speed automatic. I have only driven it around the neighborhood a few times just to see if everything works. I have noticed when I start it in park it seems to slightly lunge forward. Same thing when I rev the engine. It doesn't move much but it seems the trans. in partially in gear.
metro1 is offline   Reply With Quote
Old 07-30-2022, 07:24 PM   #2
KULTULZ
KULTULZ's Avatar
Arrow Re: Transmission problem
Check your NSS (NEUTRAL SAFETY SWITCH) adjustment.
It may be allowing the car to start in gear.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-31-2022, 12:36 AM   #3
rotorwrench
rotorwrench's Avatar
Default Re: Transmission problem
I would be curious about the proper adjustment of the linkage. There should be no clutch pistons or bands gripping in park or neutral. Park has a pawl to hold the car but it still shouldn't try to creep or move at all.
Old 07-31-2022, 06:19 AM   #4
metro1
I'll have to check the linkage and see if it's where it's supposed to be.
Old 07-31-2022, 06:49 PM   #5
metro1
Apparently the forward clutch is not adjusted properly or is stuck causing the transmission to always be partially in gear according to others having the same problem with other cars.
Old 08-01-2022, 02:18 PM   #6
rotorwrench
The aluminum case 2-speed Ford-O-Matic was not real popular. It was mostly used with smaller engines like the 144/170 6-cylinders and some 221 & 260 V8 applications in Falcons and Fairlane types. They were also use in some 292 Y-blocks and the 223/262 6-cylinders before the C4 came out in 1964.
Bands can be adjusted but clutch packs are either on or off. If a piston seal came apart then pieces might jam the piston up. If the clutch pack has springs then springs may be broken. Could be a sticky valve in the valve body. Bands can be adjusted but that's about it. The early ones before 1961 had TV valve control from the throttle linkage to set up operating pressure for throttle position. This changed in 1961 when they finally put vacuum modulators on the Ford transmissions. The valve position can be adjusted to give the proper pressure for shifting and the like and it is adjustable. It's generally only adjusted to get either a softer shift or a harder shift depending on what the operator wants.
Old 08-04-2022, 01:00 AM   #7
KULTULZ
KULTULZ's Avatar
Post Re: Transmission problem
This trans still used the FORD-O-MATIC THROTTLE VALVE SYSTEM and correct TV LINKAGE ADJ is paramount. I would verify correct linkage(s) adj before going into the trans itself.
If the linkage adj is off, it may allow the NSS to not operate correctly.
Do you have the F/M/2 SHOP MANUAL?
- WHY IS IT ... -
Old 08-05-2022, 08:17 AM   #8
cadillac512
cadillac512's Avatar
Metro, does the trans do the same thing after being fully warmed up (like a longer drive?) You may want to see if that changes things...many C4 transmissions also do the same thing when cold and it is not a problem. My '66 Fairlane will move forward a couple inches in park or neutral when started cold but not when warmed up, and the linkage and adjustments are correct. A quick search online will show many examples of this.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 08-05-2022, 02:35 PM   #9
metro1
This car is still a "work in progress" so I haven't been able to drive it except around the block a few times before I pulled it apart. I don't remember if it was a problem then. The seats have been removed but I am able to start it up and let it run for a bit. That's when I noticed the creep forward when it starts. It does the same thing in neutral and park. It could be that it's not a problem like you said. My biggest concern is the fluid dripping from the front of the transmission while it's running. I'll look more into that when I get past the never ending rust repair which I'm not really good at so it's going slow.
Old 08-05-2022, 06:53 PM   #10
cadillac512
Yes, the leak from the front while running doesn't bode well. Pump seal or gasket is a common cause. Let's hope it's simple!
I hear you on the rust repair...I'm not good at it either.
Old 08-05-2022, 07:53 PM   #11
KULTULZ
KULTULZ's Avatar
Exclamation Re: Transmission problem
It will be a very large problem if it decides to start in range (with the fast idle cam set).
You ever see one start and knock the garage wall down?
- WHY IS IT ... -
Old 08-08-2022, 11:32 PM   #12
bbrocksr
Like Terry said, not a problem a lot of them do that when the oil is cold,
Bill
bbrocksr is offline   Reply With Quote
Old 08-09-2022, 05:34 AM   #13
KULTULZ
KULTULZ's Avatar
If the car moves when started in PARK, you have a problem, simple as that.
- WHY IS IT ... -
Old 08-10-2022, 09:31 PM   #14
cadillac512
My bet, (and the OP can confirm) is the car creeps gently forward in Park only until the park pawl limits the creep. Likely two or three inches. It's really not unusual to us in the service and repair business to see this and it most likely will not be a problem with the manual valve or throttle valve adjustments, although of course it pays to check those.
Old 08-11-2022, 12:26 AM   #15
metro1
That's exactly what is does. It won't really go anywhere it just has a slight forward movement of an inch or two when it starts.
Old 08-11-2022, 06:30 AM   #16
KULTULZ
KULTULZ's Avatar
Question Re: Transmission problem
... the car creeps gently forward in Park only until the park pawl limits the creep
IF the SELECTOR SHIFT LINKAGE is in good condition and adjusted correctly ...
IF the PARKING PAWL is intact and adjusted correctly ...
IF the PARKING PAWL is not worn or decides to fracture ...
It's a 1959 MODEL, what possibly could be worn out?
I am going to leave this one alone ...
- WHY IS IT ... -
Old 08-11-2022, 05:35 PM   #17
cadillac512
You have no problem.
Old 08-11-2022, 06:05 PM   #18
KULTULZ
KULTULZ's Avatar
You forgot to add (I)n (M)y (O)pinion.
Now if the car does take off you will personally warranty any and all damage(s)? That's my take on what you just posted.
liable
lī′ə-bəl
adjective
Legally obligated or responsible: synonym: responsible.
PS -
The only reason an AT car should move when started in PARK is if it has an oversized cooling fan and it pulls the car forward.
- WHY IS IT ... -
Old 08-12-2022, 12:22 AM   #19
bbrocksr
PS -
What do you suppose happens in the torque convertor when you rev the engine up? It is a fluid coupling and it drives the input shaft which is connected to the outer clutch drum, between the outer clutch drum and the clutch hub is a series of lined and unlined disc which are only a few thousands apart with oil between them. The drag between these discs will tend to rotate the planetary gears and output shaft causing a slight creep.
More so when the oil is cold/thicker.
It will do it in park or neutral, the only difference between park and neutral is the parking pawl is engaged in park.
Bill
Old 08-12-2022, 01:00 AM   #20
KULTULZ
KULTULZ's Avatar
Thumbs down Re: Transmission problem
I think you might want to re-read the theory book on valving. If it creeps @ STARTUP/IDLE/FAST IDLE, what will the car do @ 2000 RPM?
If the car moves at STARTUP in PARK, there is a problem.
Telling a novice there is no problem is wrong.
- WHY IS IT ... -
