12-10-2018, 03:04 PM | #1 |
F-1 scrub radius
Has anyone got this number? I looked in the manuals but didn't find anything.
You'd use a line through the king pin, down to the ground.... whatever spot it hits. And then the center of the tire tread, whatever point that is sitting on the ground. It's the distance between the two points on the ground. I've got non-stock rims, so I'm going to get a non-stock answer. |
12-11-2018, 01:05 AM | #2 |
Re: F-1 scrub radius
About the closest thing to that is king pin inclination, which is shown how to measure on p. 326 of the 48-51 manual. It is spec'd at 6 deg. With some measurements of your own, I think you could calculate scrub radius.
What kind of rims are you running?
'52 F-1, EAB flathead |
12-11-2018, 06:21 AM | #3 |
The below chart, page S10 - Unit Design Features section of the 6/51 Dealer Handbook, shows turning circle diameter of 43’ on the left and 42.5’ on the right. Those diameters would have been recorded with the maximum tire size of 6.50-16” which has an outside diameter of 30”, or radius to the ground of 15” at the spindle. Would we still need the distance from the C/L of the Kingpin to the C/L of the tire to do the math? Or are there too many other variables? I’m scratching my head. Stu
Stu McMillan Marmon-Herringtons Last edited by truckdog62563; 12-11-2018 at 06:37 AM. |
