Old 10-10-2021, 08:30 PM   #1
Eccentric Old Guy
Eccentric Old Guy's Avatar
Default So why did Ford go from 21" wheels to 19" wheels?
My search on the internet gave no indication of why the switch to the smaller wheel in 1930....
I can make a guess that the roads were improving, and the larger diameter wheels weren't as much needed.
(Back in the days of the horse drawn wagons, the larger wheels went over rough roads better than smaller wheels.)
Here's some related info on the wheels:
https://www.speedwaymotors.com/the-t...928-1935/28813
Eccentric Old Guy is offline   Reply With Quote
Old 10-10-2021, 09:48 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: So why did Ford go from 21" wheels to 19" wheels?
Keep in mind they changed the way the edge was designed too, from the rolled over open 28-29 to the seamless 30-31. I consider it one of the many design improvements to 30-31 models.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-10-2021, 10:03 PM   #3
GeneBob
I suspect it had to do with tire technology. As the bigger side wall sizes became more easily produced, it provided a smoother ride. The bigger sidewall height on a smaller diameter rim absorbed smaller bumps better to give a smoother ride. Go forward into the 1960's and 1970's and the luxury cars had big tires on 15" wheels to provide a smooth ride.
Just a guess.
GeneBob is offline   Reply With Quote
Old 10-10-2021, 10:09 PM   #4
lrf
Reading what I have about Henry Ford, reducing the cost anyway he could would be reason enough to downsize the rim size. 4 wheels X 2 million cars could be a substantial savings. He was a financial genius.
lrf is offline   Reply With Quote
Old 10-10-2021, 10:33 PM   #5
JoeCB
JoeCB's Avatar
I think a styling issue (improvement? ) to enhance the "lower" sleeker look of the 30 -31 body.
Joe B
JoeCB is offline   Reply With Quote
Old 10-11-2021, 01:26 AM   #6
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
The trend continued. 18" in '32, 17", in 34, 16" in '35, 16",
Richard 15" in '49 and 14" sometimes after that.
Now the trend has reversed.
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 10-11-2021, 02:08 AM   #7
40 Deluxe
Richard
Anaheim CA
14" came out in '57. The first Falcons were 13", I believe.
Old 10-11-2021, 04:11 AM   #8
updraught
updraught's Avatar
It's so the vibrations and rattling come on board faster.
updraught is offline   Reply With Quote
Old 10-11-2021, 07:14 AM   #9
nkaminar
nkaminar's Avatar
As Richard stated it is now back to 21 inch.
File Type: jpg Screen Shot 2021-10-11 at 8.12.32 AM.jpg (10.5 KB, 472 views)
Old 10-11-2021, 09:17 AM   #10
rotorwrench
rotorwrench's Avatar
Henry Ford and Harvey Firestone were relatively close friends. As new innovative tire designs were emerging, I'm sure that Harvey made sure that the Fords knew about them. Tires with lower and wider profile would increase the comfort level of passengers in cars so equipped. Roads were getting better but speeds were also increasing.
Old 10-11-2021, 11:44 AM   #11
Jim Brierley
'48 Fords had 15" wheels.
Jim Brierley is offline   Reply With Quote
Old 10-11-2021, 06:17 PM   #12
rotorwrench
The 15" wheels were standard on the Mercury of the post war era but likely optional on the Ford cars.
Old 10-12-2021, 09:56 AM   #13
Eccentric Old Guy
Well, I guess we've not definitively answered the question of why the model A went from 21" wheels in 1928-29, to 19" wheels in 1930-31. I thought the answer to that would be common knowledge, but I guess not!
Probably has more to do with engineering and cost related things, than anything to do with changing road conditions.....like I originally opined.
Old 10-12-2021, 11:45 AM   #14
rotorwrench
Henry drove one of the first model A prototypes over a rough ground course. After he finished, he told the engineers to install shock absorbers. Mr. Ford wanted good cars to be sold at low prices so it wasn't always about the cost analysis. He knew that short falls could be more than made up for by mass production and sales. After the bottom fell out of the economy in late 1929, most industrialists knew that they had to keep up with the Joneses so improvements were always being made to the product even in hard times. The new type rim holds the tire on better and the 19" wheel and cap had a more modern look to them. It was a win win change. I don't know what other answer there would be.
Old 10-12-2021, 03:35 PM   #15
Ivan in southeast va.
Ivan in southeast va.'s Avatar
And...better centrifugal force.
Ivan in southeast va. is offline   Reply With Quote
Old 10-12-2021, 06:09 PM   #16
updraught
updraught's Avatar
That is due to the huge brakes for the Autobarn and low profile tyres.
Old 10-18-2021, 08:24 PM   #17
ericr
ericr's Avatar
was it simply a styling adjustment?
ericr is offline   Reply With Quote
Old 10-19-2021, 10:16 AM   #18
katy
katy's Avatar
Probably just downsizing like everybody else was.
