Old 05-10-2010, 06:13 PM   #1
41ford1
41ford1's Avatar
Default Brake upgrade on a 41 pickup ??
I've had this truck for a few years now. My major issue with it is brake performance. I would like to make the old girl stop better. Too many crazys in the road these days. I am thinking of using a Speedway kit to convert it to disc brakes or putting the self energizing brakes on it from a 53 to 56 F100. I guess I'd like to hear what you guys have experianced with both of these conversions. BTW I am running a dual circuit MC for a 68-9 Mustang
41ford1 is offline   Reply With Quote
Old 05-10-2010, 06:22 PM   #2
41PICUP
41PICUP's Avatar
Default Re: Brake upgrade on a 41 pickup ??
I used a kit from ECI on the front and Lincoln brakes from MT Car Products on the back. Both ECI and MT are great to do business with.
41PICUP is offline   Reply With Quote
Old 05-10-2010, 06:57 PM   #3
CWPASADENA
CWPASADENA's Avatar
Contact Richard at the Early V-8 Garage. He sells brake parts and kits for all the early V-8s and also has up-Grade kits available. He really knows what is going on and great to work with. [email protected] or (626) 338-2282.
CW
CWPASADENA is offline   Reply With Quote
Old 05-10-2010, 07:06 PM   #4
Bob
Ihave done 3 of these disc front drum rear the m/c should work ok but have had better luck with adodge pickup worked better 1in bore . You won,t be happy with out power asst. get a8in dbl dia.
Bob is offline   Reply With Quote
Old 07-30-2010, 08:07 PM   #5
41ford1
41ford1's Avatar
Just an FYI update. I used the Speedway kit with the 40 drums in the rear. I had earlier converted to a dual circuit MC using a 69 Mustang unit 1" bore. Braking performance was much improved. The only issue was low pedal, about an inch off the floor. I remedied that by changing the MC to one for a 70 Chevy/GMC 1 1/8",(same bore as the original Ford single). The pedal is now high, about 1 1/2" from the top. Pedal force is a little higher than my 04 Chrysler, but it is not objectionable. I don't see the need to add power assist to this set up.
Old 07-30-2010, 08:42 PM   #6
paul2748
paul2748's Avatar
I put the F100 brakes on mine and like the way it stops. 40 type brakes on the rear. I have a write up on this if you are interested.
Old 07-30-2010, 09:13 PM   #7
steve-cook
steve-cook's Avatar
http://www.jalopyjournal.com/forum/showthread.php?t=200
steve-cook is offline   Reply With Quote
Old 07-31-2010, 09:45 AM   #8
TJ
TJ's Avatar
Go with the disc brakes up front. I've used the F-100's, but the disc set up is far superior.
