Old 07-11-2016, 08:20 PM   #1
Prawbly
Prawbly's Avatar
Send a message via AIM to Prawbly
Default 35 drums to 36
Good evening all. I know I have read a post dealing with this but I can't find it. I want to know if the drums on a 35 will fit a 36. I'm trying to get rid of the wide five. I have been told that it is just a bolt on change. Sounds good, but I want to do it right. Thanks, Pat
Prawbly is offline   Reply With Quote
Old 07-11-2016, 08:48 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 35 drums to 36
The problem is that the spindles on the '36 are goofy. Well, maybe not "goofy" as such, but they are a one-year-only length that require '36-only front drums. '35 or '37-'40 spindles will bolt-on, allowing you to use '40-'48 front drums. You can use '40-'48 drums on the rear. DD
Click Links Below __
T5 W/TORQUE TUBE
V8COOPMAN is online now   Reply With Quote
Old 07-11-2016, 09:44 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
Rear drum/hubs are bolt on, '35 to '36 and vice versa. Using '35 front drums on a '36 with mechanical brakes, requires the use of '35 spindles. Now if you go with hydraulic brakes, the '37-'40 spindles, '39-'40 backing plates, and '40-'48 drums will also get you to a 5 on 5-1/2" bolt pattern. Depending on which drums and wheels you decide to go with will determine whether or not you need spacer/support rings between drums and wheels.
John
Old 07-11-2016, 09:56 PM   #4
Prawbly
Prawbly's Avatar
Thanks to you. Many thanks. I was dreading going through a lot for just wheels. Thanks a million, now to find the parts I need. Pat
Old 07-11-2016, 10:02 PM   #5
Brian
Brian's Avatar
Actually...you can use your 36 spindles with 35 drums. That is the exact setup I run. All you'll need to do is shorten the castle nut[s] up sufficiently to allow fitting of the cotter pin[s]
