Old 03-24-2016, 09:15 PM   #1
Prawbly
Prawbly's Avatar
Send a message via AIM to Prawbly
Smile 1935 wheels
Hi all
I really like the 1935 wire wheel. My problem is I have a 36 with the wide fives. My question is will the 35 hubs fit on my 36 without problems. Thanks Pat
Prawbly is offline   Reply With Quote
Old 03-24-2016, 09:49 PM   #2
Dave D
Default Re: 1935 wheels
No, the front spindles are longer. You can swap spindles though.
Dave D is offline   Reply With Quote
Old 03-24-2016, 09:55 PM   #3
Brian
Brian's Avatar
Actually, although the spindles for a 35 are longer, you can get by using 35 drums on 36 spindles by facing a bit off the back side of the castle nut that holds it all together. Works fine; I've been running that exact combo for years.
Old 03-24-2016, 10:04 PM   #4
tubman
tubman's Avatar
If there is enough room on the end of the spindle, how about getting the proper size die and cutting a couple of more threads?
