Old 06-17-2020, 07:57 PM   #1
eicke
Default Flathead Guru's...Question on installing the crankshaft sleeve
For the Guru's........which direction do you install this sleeve? I should have paid attention when I removed it. Notice the offset in the spiral. Installing it either direction will pull oil back into the engine. Try'd that. Was going with a one piece seal and didn't like the sloppiness of the fit on the crankshaft. Decided to go old school and use the rope seal. BTW, 1950 8BA.
eicke is offline   Reply With Quote
Old 06-17-2020, 08:58 PM   #2
eicke
Default Re: Flathead Guru's...Question on installing the crankshaft sleeve
Not 100% on this but I believe the top on this pic goes IN towards the crankshaft/slingert.
Old 06-18-2020, 07:37 AM   #3
eicke
Anyone?
Old 06-18-2020, 08:44 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
This is a bushing off of an unmolested/never rebuilt engine that shows the seal fully engaged with the spirals towards the front, not towards the crankshaft.
Old 06-18-2020, 10:31 AM   #5
eicke
This pic is from DIYFORD (H & H's Mike Herman doing the rebuild)
Old 06-18-2020, 10:37 AM   #6
eicke
And another from DYIFORD.com.....(a little tough to see)
Old 06-18-2020, 11:35 AM   #7
flatheadmurre
flatheadmurre's Avatar
That spiral is there to pull the oil back into the engine...no good if it stops in the middle of the rope seal...
Take a look at the early sheeves that has it built in if in doubt.
So spiral goes in towards gear.
Old 06-18-2020, 12:09 PM   #8
19Fordy
19Fordy's Avatar
If the crank turns CW, doesn't the bushing have to be installed like 51MERC-CT shows so as to "spiral" the oil back towards the engine?
Old 06-18-2020, 12:19 PM   #9
flatheadmurre
Spiral dont care which way its installed...same as a bolt its either right or left hand...no matter if your turning the bolt or the nut...
Old 06-18-2020, 01:45 PM   #10
eicke
Yep....tried that. Either way the spiral would pull it back into the engine.
Old 06-18-2020, 01:50 PM   #11
eicke
I kinda agree, Mike Herman built 100's if not thousands of flatheads and putting on a sleeve backwards would be a rookie mistake which is possible but not likely.
Old 06-18-2020, 03:59 PM   #12
Tony, NY
I used a Speedi-Sleeve with the one piece seal.
Tony, NY is offline   Reply With Quote
Old 06-18-2020, 07:03 PM   #13
deuce_roadster
deuce_roadster's Avatar
Put your thumbnail in the groove, view it from one end and turn it the way the crank shaft goes (Clockwise when viewed from the front) Which way does your thumbnail move? This will tell you what you want to know without looking at any pictures.
Old 06-18-2020, 08:11 PM   #14
flatjack9
flatjack9's Avatar
In the picture in #1 post, the top side goes against the crank gear,
Old 06-19-2020, 09:22 PM   #15
eicke
Thanks, That's the way I installed it. I've rebuilt quite a few motor and it's usually the little things that stump me.
Thread Tools
Display Modes
