Old 11-10-2020, 04:23 PM   #1
coyledad46
Default door handles and slide lock questions
My 1930 Standard Coupe has door handles with key locks on both sides. (Of course, I have no keys.) The slide lock is on the driver's side, but there's no knob to operate it (See picture). What am I supposed to have? I think the outside locking handle is supposed to be on the passenger side, but that seems inconvenient, having to slide across the seat to exit on the passenger side.
What's missing in the picture? The knob, of course, but there's nothing to screw the knob onto. Do I need to replace the whole slide lock?
Silly questions, but someone once said, "The only dumb questions are the ones you didn't ask."
coyledad46 is offline   Reply With Quote
Old 11-10-2020, 04:37 PM   #2
TMarsh
Default Re: door handles and slide lock questions
That drivers side key lock was added by po. They reasoning behind the original was exit on curb side and lock passenger door with key. There was a slide lock (inside) that you are missing. No key on drivers side. Vendors have what you need, not expensive.
TMarsh is offline   Reply With Quote
Old 11-11-2020, 07:16 AM   #3
desotoguy
If you wish to replace the outside handles and have a keyed lock, Speedway Motors has a set of two, keyed alike handles. For my convenience, I wanted a locking handle on the driver side.
desotoguy is offline   Reply With Quote
Old 11-11-2020, 08:23 AM   #4
Ray64
Ray64's Avatar
Looks like a hole in there to screw the knob in to me
Ray64 is offline   Reply With Quote
Old 11-11-2020, 12:08 PM   #5
Bob C
Looks like this is what you need.
https://www.brattons.com/slide-door-lock-assembly.html
Old 11-11-2020, 05:29 PM   #6
CarlG
CarlG's Avatar
I bought keyed alike outside handles from CW Moss. When I put new door panels on, I just covered over the slide lock like it was never there.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-18-2020, 04:07 PM   #7
Superhart
Superhart's Avatar
Another thought is to add a sliding lock lever to the passenger side door as well as locking handles on both sides. Yeah, I am quite lazy and want convenience. Admittedly, you must be very careful NOT to lock both doors at the same time using the slide lock mechanism or you will be locked out of the car. The only way to get in would be to remove the hinge pins on one door to gain access. That being said, the conversion of the passenger latch to operate with a slide lock is fairly straight forward should you wish to attempt it. Here is a link to the article I posted describing the modification needed:
https://www.fordbarn.com/forum/showt...=279171http://
Superhart is offline   Reply With Quote
