Old 04-26-2016, 01:45 PM   #1
glennpm
glennpm's Avatar
Default 1932 exhaust pipe hangers?
Hi,
Looks like there is no source for 32 exhaust/tailpipe hangers, at least that I can find. Has anyone used later year hangers successfully? The one that would be perhaps the hardest is the one that mounts on the rear frame cross-member, adjacent to the hole for the pipe.
Thanks
Old 04-26-2016, 03:47 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 1932 exhaust pipe hangers?
At one time Mike McKinnett in OR reproduced the entire exhaust system both early and later, including hangers. Not sure of the spelling of his last name, might be McKennett. I think his shop is in Gresham Or.
Old 04-26-2016, 04:27 PM   #3
DavidG
DavidG's Avatar
Your second spelling of Mike's name is correct. The address of his business, Restorations and Reproductions, has a Portland street address. I'm pretty sure that not a single piece of his outstanding exhaust system reproductions remains, but no harm in asking.
While it is a bit of sin to do so, it is pretty easy to modify an easier-to-find '33-'34 tailpipe hanger (at the rear cross member) to create the '32 version.
Old 04-26-2016, 06:07 PM   #4
glennpm
glennpm's Avatar
Thanks!
I found his info here:
https://fordbarn.com/forum/showthread.php?t=52628
Old 04-26-2016, 08:30 PM   #5
corndog
corndog's Avatar
Glenn, I have some exhaust hangers that might be 32 ford. Do you have a sourec for a picture or someway for me to tell if what I have is what you need? Paul in Indiana
Unspoken gratitude is helpful to no one.
corndog is offline   Reply With Quote
Old 04-26-2016, 08:37 PM   #6
glennpm
glennpm's Avatar
Hi Corndog,
I can't send a picture until after Mother's Day. I'll then be able to send a picture from The 32 Ford book that I have. From memory, it clamps around the tailpipe just in front of the hole for the same and has a rubber biscuit and bolts to a hole adjacent to the large hole for the pipe.
Appreciate you replying!
Regards,
Glenn
Old 04-26-2016, 08:52 PM   #7
jim1932
jim1932's Avatar
are you talking v=8 or 4?
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 04-26-2016, 09:51 PM   #8
corndog
corndog's Avatar
Glenn, here is what I have. It came to me in a box of original 32 ford parts i bought from an older guy 10 years ago. Paul
Old 04-26-2016, 11:11 PM   #9
DavidG
DavidG's Avatar
Paul,
While not the '32 hanger in question, it could easily be made into one as its "tail" is more than long enough. That's what I've had to resort to of late.
Jim,
The hanger (clamp/bracket) at the rear cross member is common for both fours and V8s.
Old 04-27-2016, 08:07 AM   #10
ct1932ford
ct1932ford's Avatar
A couple of different versions I have made over the past few years. They were on hot rods so did not have to look like originals. But they are made of stainless steel.
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 04-27-2016, 08:39 AM   #11
glennpm
glennpm's Avatar
Very nice. I've used those torca clamps on motorcycles before and they're very good.
Old 04-27-2016, 01:03 PM   #12
Corn Fed
Corn Fed's Avatar
I agree. I've taken some off a 34 big truck that could easily be shortened and bent to mimic a 32.
Corn Fed is offline   Reply With Quote
