Old 09-16-2015, 05:42 AM   #1
ron hebb
Default 1956 ford
hi
are they any late models replacement rearends for 1956 ford.
something that somebody used without to much trouble
thanks for any help
ron hebb is offline   Reply With Quote
Old 09-16-2015, 06:28 AM   #2
ron hebb
Default Re: 1956 ford
that is 1956 car
Old 09-16-2015, 06:56 AM   #3
darrell
theres several my 56 has a mustang rear from a 65 or 66.its more or less a drop in expect for drivrshaft.some use a 57 or 58 .both match up with your springs.
darrell is offline   Reply With Quote
Old 09-16-2015, 07:24 AM   #4
okiedokie
okiedokie's Avatar
I believe a Maverick is a good fit also.
okiedokie is offline   Reply With Quote
Old 09-16-2015, 07:43 AM   #5
Ford blue blood
Ford blue blood's Avatar
and Granada/Monarch. Don't over look the early Ranger, some were 8.8 and narrow but require spring mount work.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 09-16-2015, 09:47 AM   #6
frank long island
frank long island's Avatar
as stated ranger will fit with perch replacement depending on what your doing you could use a disk rear which is what I did in my wagon make sure you get all the mounts and drive shaft flange to rear end as this bolts to rear the only fab work I did was shock mounts to use original shocks if you need more info on ranger rears ck out ranger station . com
frank long island is offline   Reply With Quote
Old 09-16-2015, 07:10 PM   #7
Ole Don
Ole Don's Avatar
A 1990 Ranger Super Cab 4x4 will have the correct width, usually a 3.73 ratio, and factory Traction Lok. It will need the spring perches cut off, and new ones welded on.
Always be careful with four cylinder Rangers and some Fairmont/ Mustang with small engines. They will have brakes way to small to use on a big sedan like a 54 - 55 - 56.
Ole Don is offline   Reply With Quote
Old 09-19-2015, 10:51 PM   #8
WestCoast
Type Hi Q Ties in your search box and it will take you to a site with the info you want, also type Jegs rear end info, scroll down a little till you find 9" ford rear axle info Jegs
WestCoast is offline   Reply With Quote
Old 09-20-2015, 07:22 PM   #9
paul2748
paul2748's Avatar
Depends on your definition of "not too much trouble"
The only ones I know that bolt right in without modification are the 65-66 Mustang (8 inch) and the 57-58 Fords (9 inch). 59's are the same length, but not sure if the spring mounts are the same. All the rest have different lengths and spring mounts. Granada's are close, but are a little wider and the spring mount location is different
The V8 Maverick (don't use the 6 cyl) is a little shorter and as far as I know have different spring mount locations.
The other ones mentioned will work, but will require some modification
48 Ford Conv
56 Tbird
54 Ford Victoria
