Old 08-24-2021, 09:18 AM   #1
Oldgearz
Default Blocking the Firewall Heater Tube
Been trying to find an easy way to block the firewall heater tube on the engine side during the summer. Had a tin foil cap with hose clamp that worked but looked pretty bad. Did an internet search and found nickel plated (shiny) steel 2" metal snap-in panel plugs from [email protected] for $7.95 for 10 pieces. They look great when inserted in the tube. You need to have 1/2" or so space between your heater and and the tube to get it in place. Thundered down the highway at 50 mph and it stayed in place just fine.
Oldgearz is offline   Reply With Quote
Old 08-24-2021, 09:33 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Blocking the Firewall Heater Tube
Thanks for the Tip!!
www.whidbeymodelaclub.com
Old 08-24-2021, 09:34 AM   #3
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Remove the manifold cover and clamp on a spray can top. Looks good and fits good.
Jacksonlll is offline   Reply With Quote
Old 08-24-2021, 11:57 AM   #4
Leon
Use the plastic endcap from a grease tube. They fit perfectly without the need of any clamps.
Leon is offline   Reply With Quote
Old 08-24-2021, 02:08 PM   #5
Werner
Werner's Avatar
Hi Oldgaerz
do you have a picture, please?
btw: I stuff a knob of "butter bread" aluminum foil in the front of the entry hole.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 08-25-2021, 06:11 PM   #6
whirnot
whirnot's Avatar
I use the brass cap from an old fly rod tube. Looks great!
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 08-26-2021, 08:04 AM   #7
dmaxweb
dmaxweb's Avatar
I used one of these. Painted black.
https://www.lowes.com/pd/Oatey-PVC-T...itting/3880607
dmaxweb is offline   Reply With Quote
