10-12-2017, 06:40 PM | #1 |
59 head studs vs 8ba head bolts
Can this been done. Can I use 8ba head bolts in lieu of 59 head studs .i haven't check bolt for thread length .
"I can't cry as long as I know the Lord has risen " |
10-12-2017, 06:41 PM | #2 |
Re: 59 head studs vs 8ba head bolts
Yep.
10-12-2017, 07:22 PM | #3 |
Thanks
10-12-2017, 07:25 PM | #4 |
I prefer the studs myself, but others, such as Ol Ron, prefer the bolts.
10-12-2017, 07:30 PM | #5 |
Studs are OK, unless you have to remove your heads someday.
10-12-2017, 07:32 PM | #6 |
10-12-2017, 09:54 PM | #7 |
The way the heads on my engine fit so tight on the studs, I would worry about having trouble getting the bolts to start perfectly and possibly messing up the block threads.
I thought about opening up the holes in the heads a little bit so they wouldn't be so tight. Decided against doing that and just used a rubber mallet to help the heads go down. Could be the studs weren't perfectly straight, don't know.
Nothing wrong with it except for the name on the front. Alex |
10-13-2017, 01:17 AM | #8 |
There was a thread on here recently about opening up the holes on the heads a bit to prevent them being too tight.
I do not recall the exact oversized diameter, but someone may remember and chime in. |
