I have a 1936 Ford 5 window coupe. I looked at the stamping on the banjo. It looks like 9-37 or 4:11 ratio. I feel like the max comfortable speed on the setup is 50-55 mph. What speed could I get from 3.78 gear ratio or other gear ratio if I am trying get more speed for hiway driving?
Thanks for replies! |
I put a 3.78 R&P in mine. best thing EVER!
No problem from a still start and much better top speed. Don't forget the need to stop as well! |
#3 | |
![]() Quote:
I currently have a '36 roadster with the stock 4:11. It was very "comfortable" around 50 - 55. I'd installed a Columbia only because I had a beautiful one "on the shelf". I still do not exceed 55, but the difference in the entire driving experience is amazing. The car has seemed to "smooth out" beautifully. If a Columbia is not in your future, I'm a firm believer that a swap to the 3:78 would make you one happy camper ![]() One thing you may want to keep in the forefront of your mind is that while a higher gear set will allow the engine to run easier at higher speeds, you're still driving an 84 year old car. Faster than 55? Ya still need to stop when that jerk in a BMW pulls right in front of you and hits the breaks. Ya also need to swerve out of his way. Good luck doing either safely at 55. At 70? Well, nice knowing you...
My very stock '36 Phaeton, when we got it around 2009 with the 4.11 gearset was "done for" at about 55mph, like you are reporting. I'm pretty sure it would have handled more, I wasn't going there.
After CharlieNY supplied a rear with the 3.78 set the top end speed went up 10 to 15 mph. The car could do over 70 if I was brave enough.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
I get 70 to 75 out of my 3:78's on occasion, other than that I'm like Kube, 55.
Paul in CT |
One of the rules I try to follow is; solve problems, don't create them. That said, trying to purchase a used 84 year old rear end in lieu of new components that are installed by a good mechanic does not make much sense.
I second Kobe's comment about a Columbia OD.. My '36 has a Columbia under it, has had since it was new. The gear ratio is 3.78 with about 25% OD. The car is very smooth running with good fuel mileage. If you consider a Columbia you are not stuck with the mechanical shifting '36-40 unit's, the later model '46-48 units, electric over vacuum, will go right into a '36 with no modifications, using the right combination of parts. I converted the Columbia under my '36 to a '47-48 unit in 1955.
Bill.... 36 5 win cpe |
#8 | |
![]() Quote:
rpms = (axle ratio x mph x 336) / tire diameter To determine the mph at a given rpm just rearrange the equation. mph = (rpm x tire diameter) / (axle ratio x 336) |
Throwback I am rambling again LOL. Most all vehicles were 4:11 4:56 whatever. So I
time travel and lucky I saw and drove yes a 36 ford here most roads were gravel even into high school early 60s in which 45 mph was speeding. So you go for parts or food in the city and you are lucky to get to 3rd speed. those days were tire chains and stay in a rut. so these were made for that time and for most times lasted into the early 50's. There are no super hy ways yet. Now . my car has 3:78s all vehicles I ever drove has sweet spot so this car with foot just resting on the gas pedal kind of likes 55 with no noise no over revs I have punched it to 80 but shame I'm too old. My boy has a 1950 4 dr. this is like day and night 65-70 silent so I suspect 3:54s ? You have a closed drive shaft so its either columbia if you take a loan out or Mitchel over drive. The Mitchel maybe the best option. again I'm ramblin with hey fever....sam |
This didn’t copy well but still decipherable.....
1935 Ford 85hp @ 3800 rpm Std Ratio Columbia Std Ratio Columbia Speed3.78 2.7 4.11 2.7 45 2041 1460 2221 1587 50 2268 1621 2467 1764 55 2494 1783 2714 1940 60 2721 1945 2961 2117 65 2947 2107 3207 2293 70 3174 2269 3454 2469 77 3799 84 3809 100 3242 3528
Tim Downtown, Ca |
I cleaned up the rows and columns.
Engine revs isn't the only consideration.
Engine noise may be reduced but road noise, tyre noise, wind noise, road/tyre induced harshness (vibrations) will not be. You need to consider the brake performance too higher speeds demand better brakes, especially if in and amongst modern traffic. Tyres, too. A tyre that is perfectly happy at 55 mph might not be too happy at 70 plus. Generally, though, a taller axle ratio will make for a more comfortable ride, but won't necessarily make the cruising speed much higher. It just makes it more comfortable at any given speed, providing the motor has the torque to pull that speed. Mart. |
#13 |
Using a Mark Williams gear ratio computer the RPM reduction you will see at 60 MPH going from the 411 to the 378 would be 200 RPM. Now if you go to the 354 ratio the RPM is now 2400 RPM lowering 200 more RPM for a total of 400 RPM less when compared to the 411 gear. The calculation I used was based of a 30 inch tall tire. Making a decision to change the rear gear considering the time and expense involved giving some thought to going to the next step which would improve economy a lot might be a wise decision. Any stock flathead would have the torque needed if the 354 gear ratio is being used.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder and Driver of the First Ford Flathead bodied roadster to run 200 MPH Record run July 13, 2018 LTA timing association 200.921 from a standing start in one and a half miles burning gasoline. Last edited by Ronnieroadster; 10-19-2020 at 02:14 PM. |
#14 |
In my 36 I am building I am using a 3.25 ratio, BUT I am also using the 29 tooth transmission cluster which in my opinion is the trick ticket with a 3.54 or 3.25 especially if you live near hills like me.
Of course a Columbia with a 3.78 is a dream but also lots of $$ |
