Old 01-12-2020, 11:17 AM   #41
brokenspoke
Default Re: Oil Filter Model A on timing cover
This is how I did mine
brokenspoke is offline   Reply With Quote
Old 02-12-2020, 04:17 PM   #42
Werner
Werner's Avatar
Guten Abend.
Today the oil filter is also installed. I will report how much dirt it gets out of the oil circulation. But it takes 10,000 mls until I cut it open. Before that, I'l report how the oil pressure display changes and the circulation temperature.
BTW, the blue stripe on the filter head shows the reached temperature.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 10-04-2020, 08:04 AM   #43
Charlville
Charlville's Avatar
Got the Mike's Affordable kit on my 29 , some info and pics here oil way cleaner
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 10-04-2020, 11:55 AM   #44
Ernie Vitucci
Good Morning....No Fram Filter...so which filter is your favorite? Ernie in Arizona
Old 10-04-2020, 01:35 PM   #45
Charlville
Charlville's Avatar
Motorcraft, Wix or K&N filters for me
Interesting article on oil filters here https://automotiveamerican.com/2018/...-russ-w-knize/
Kevin Flood
West Berkshire UK
Old 10-04-2020, 03:24 PM   #46
Chris Haynes
Chris Haynes's Avatar
My oil filter is full flow.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-05-2020, 09:38 AM   #47
katy
katy's Avatar
So is the side cover mounted one.
Old 10-06-2020, 01:50 PM   #48
RB_Nielsen
RB_Nielsen's Avatar
Wix 51515 or Napa 1515 (made by Wix) oil filters that fit the valve cover set up
RB_Nielsen is offline   Reply With Quote
Old 10-06-2020, 03:47 PM   #49
Y-Blockhead
Y-Blockhead's Avatar
I use the Wix. It is already painted black and the label just peals off. Looks better 'hidden', IMO
Old 10-06-2020, 03:53 PM   #50
Y-Blockhead
Not to change the subject but what head are you running?
