10-16-2020, 11:09 AM | #1 |
35 Ford Hubcaps
I recently installed 35 Ford wheels on my 30 CCPU. I purchased new hubcaps from Snyder's that fit reallllllly well. The problem is these hubcaps are extremely hard to remove. Is there a special tool that Ford sold to remove these hubcaps without marring the paint/powder coat finish on the wheels?
AL in NY |
10-16-2020, 01:15 PM | #2 |
Re: 35 Ford Hubcaps
Wood wedge or one of those plastic (really strong) ones that Stihl sells for driving in a tree. Just something to get it started to where you can grab it.
10-17-2020, 08:09 AM | #3 |
Re: 35 Ford Hubcaps
I use the yellow plastic bondo spreaders you pick up at swap meets etc. Place the thin edge between the hubcap and wheel then use a flat screwdriver to pry against the yellow spreader. Have done this for years with no paint chips etc.
Pat |
10-17-2020, 08:21 AM | #4 | |
Re: 35 Ford Hubcaps
Nice method Pat, kinda like using wide putty knives to protect drywall/trim when prying kick boards/mop boards/trim off drywall. Going to try this instead of my method above, next time. |
10-17-2020, 03:43 PM | #5 |
Re: 35 Ford Hubcaps
A well tested procedure.
10-17-2020, 05:58 PM | #6 |
Re: 35 Ford Hubcaps
AL in NY |
10-17-2020, 06:10 PM | #7 |
Re: 35 Ford Hubcaps
10-17-2020, 01:58 PM | #8 |
Re: 35 Ford Hubcaps
Harbor Freight has a set of plastic tools, so I'm told.
Paul in CT |
10-17-2020, 02:50 PM | #9 |
Re: 35 Ford Hubcaps
HF sell a hard plastic tool, this one came from a Swapmeet it is 1” wide w/a double taper and a sharp edge to get into the seam.
Works well-
Tim Downtown, Ca |
10-17-2020, 11:06 PM | #10 |
Re: 35 Ford Hubcaps
I use a 3 or 6 inch putty knife and a screw drive, putty knife in place between tire and rim, a little pull outward and if the cap doesn't move right away I then shove the screw driver between the cap and putty knife. Haven't hurt my powder coating in twenty years. Rubber hammer to refit.
