Old 02-22-2024, 02:49 PM   #1
andyford
Default 38 Ford Body to Frame Bolt Help Needed
I have a rubber pad mount set with sheet identifying pad locations and a Vintique Body to Frame bolt kit. In this bolt kit there are around 16 coach headed bolts and 14 hex headed bolts. As the floorpan has been replaced prior to my ownership (no fixing holes drilled) I have no idea which type of bolt should go where - does anyone have a diagram showing which type of bolt matches to the pad locations?
Thanks A
andyford is offline   Reply With Quote
