Old 02-09-2023, 06:50 PM   #1
STAN WHITE
Default 59AB Front cam cover Special 5/16 18 cap screws
I need five or ten of theses special hex head cap screws thread is 5/16 18 pitch. they have a shoulder just below the hex head that is a few thou larger than the thread o.d. Does anyone know where to get these. The larger shoulder dia is for alingment for DISTRIBUTOR CONCENTRICITY ! . Thanks Stan White
STAN WHITE is offline   Reply With Quote
Old 02-09-2023, 07:07 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 59AB Front cam cover Special 5/16 18 cap screws
Try looking at pressure plate bolts, they have a shoulder too
Old 02-09-2023, 07:14 PM   #3
Mart
Mart's Avatar
Pressure plate bolts have a longer shoulder and a shorter thread than the distributor bolts. In a pinch you might use a longer bolt that has a short non threaded shank and cut the thread down. I'm not sure if the proper distributor bolts have a larger shank than normal (5/16").
I don't think it is that critical to a few thou.
Old 02-09-2023, 07:40 PM   #4
NealinCA
NealinCA's Avatar
Aren't these the same as the shouldered bolts also used for the transmission top?
Either way, Third Gen carries both. One plated, others black
https://thirdgenauto.com/product/193...over-hardware/
https://thirdgenauto.com/product/193...-headed-bolts/
NealinCA is offline   Reply With Quote
Old 02-10-2023, 06:46 AM   #5
Dak Rat
Yes, The transmission top bolts are the same as the front cover bolts.
Dak Rat is offline   Reply With Quote
