08-17-2020, 02:24 PM | #1 |
Pressure Plate
Wondering which is the superior design....9" '34 Sedan - Street
#1 or #2
08-17-2020, 02:48 PM | #2 |
Re: Pressure Plate
I ordered a replacement clutch from RAM and they sent me a three finger design (like number two). I believe the original clutches were three finger design, but I can't say that for sure.
The three finger design uses the centrifical force of the spinning clutch to add pressure to the pressure plate - as the engine speeds up, it pushes down harder (you can see the weights in your picture). My upgraded engine will use a diaphragm style of clutch (sort of like your picture #1, but with fingers all the way around). Apparently they are easier on your left leg. |
08-17-2020, 03:14 PM | #3 |
Re: Pressure Plate
Won't it depend on which flywheel you have?
08-17-2020, 03:17 PM | #4 |
Re: Pressure Plate
Never saw one like #1.
Stick with #2. |
08-17-2020, 03:39 PM | #5 |
Re: Pressure Plate
#1's started with 29 A's, went thru 34. 28 A's were the multi disk things the early racer's liked
08-18-2020, 02:36 PM | #6 |
Re: Pressure Plate
#1 is for a RECESSED / STEPPED FLYWHEEL #2 is for a FLAT, NON-RECESSED STYLE FLYWHEEL
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 08-18-2020 at 03:34 PM. |
08-18-2020, 03:47 PM | #7 |
Re: Pressure Plate
That is correct. Ideally do to design, weight and force needed to actuate the clutch the #2 in your photos (35-up design) would be ideal. But if your 34 has the original flywheel it will take the other.
08-18-2020, 04:31 PM | #8 |
Re: Pressure Plate
Thanks for your reply, Mike. I won't know what flywheel I have until I pull the tranny - my flywheel could have been replace sometime in the past. I'm thinking that if I do have an original recessed/stepped flywheel, I would be better off replacing it with a flat non-recessed style. Am I correct in assuming the original flywheel is strictly for a 9 inch clutch and that the 35-up flywheel will accommodate a 10-10 1/2 inch clutch?
Do you sell a kit that includes the 10-10 1/2 inch flywheel with ring gear, clutch disc and pressure plate?
08-18-2020, 04:54 PM | #9 |
Re: Pressure Plate
The Long style applies more pressure to the clutch plate as RPM increases due to the fly weights, it is a much better pressure plate than the Borg Beck.
08-18-2020, 05:28 PM | #10 | |
Re: Pressure Plate
We sell clutch kits but in terms of flywheels, all I would have are used ones Last edited by 35fordtn; 08-18-2020 at 08:13 PM. |
08-18-2020, 07:26 PM | #11 |
Re: Pressure Plate
Today I removed the clutch from my 1934 ton and a half truck. It has the Borg & Beck style with 6 fingers (#1). The plate measures 10". Green book tells me this was truck only as is the flywheel. I haven't looked for a replacement as yet. I
