Old 02-14-2017, 08:40 AM   #1
Doug 845
Default 1933 Ford V8 Oil Pump Screen Cover Gasket
Where can I find a gasket for an original style pump? I found a new screen at Macs (model A type B-6623), but can't seem to find a gasket for the screen cover. The gasket offered by them is oval while the original is round 2 3/4".
Doug 845 is offline   Reply With Quote
Old 02-14-2017, 09:22 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 1933 Ford V8 Oil Pump Screen Cover Gasket
Don't recall ever seeing a gasket between the screen and the cover.
Perhaps this will help you in pointing it out.
Old 02-14-2017, 10:34 AM   #3
Terry,OH
Terry,OH's Avatar
Yes the original 32-34 oil pumps do have the gasket. They can be made if you have a gasket circle cutter.
Old 02-14-2017, 11:26 AM   #4
34PKUP
34PKUP's Avatar
Or an Xacto knife and pair of scissors?
34PKUP is offline   Reply With Quote
Old 02-14-2017, 01:02 PM   #5
barnfind08
I have these in stock
barnfind08 is offline   Reply With Quote
Old 02-14-2017, 09:22 PM   #6
Brian
Brian's Avatar
Any good complete engine gasket set should contain one of those gaskets; seldom used as not many people run those real early pumps.
Old 02-14-2017, 10:26 PM   #7
DavidG
DavidG's Avatar
The NOS or NORS versions made of cork more often than not have shrunk and will not fit over the screen and even if carefully worked will split.
