02-11-2017, 01:48 PM | #1 |
1934 Oil Pan Removal
I figure out how to post my pics. Here are the pics for my oil pan removal.
02-11-2017, 02:21 PM | #2 |
Re: 1934 Oil Pan Removal
Good on you I took my pan off in place was a pain!
02-12-2017, 07:04 AM | #3 |
Can someone tell me if one of the gears in the oil pump is suppose to be lose like in my pic. When I took the screen cover off I discovered one bad screen and a lose gear. Also, by looking at the first pic, does it show the block to be a '33 / '34 versus a '35 / '36?
02-12-2017, 07:52 AM | #4 |
Yes, one of the gears should be loose as it is held in place on its shaft by the bottom cover. Judging from your first photo you have a '33-'34 engine block.
02-12-2017, 12:43 PM | #5 |
Thanks David. That is what I was hoping for in both cases.
02-12-2017, 03:04 PM | #6 |
