Old 07-15-2019, 12:00 PM   #1
grumppyoldman
grumppyoldman's Avatar
Default Short shocks on rear of 55
Found that the rear shocks will not let the rear axle drop down far enough to get the tire and wheel off the axle. Had to disconnect the bottom of the shock so I could get the tire on. What shock length should I use on the 55 rear end? Al
grumppyoldman is offline   Reply With Quote
Old 07-15-2019, 12:30 PM   #2
JeffB2
JeffB2's Avatar
Default Re: Short shocks on rear of 55
I had the same issue on my '54 which uses the same shocks the new Gabriel part number was 81270,I took one off and the extended length compared to the old original shock was almost 2" shorter so i had a pair of these in my parts bin and it solved the problem: https://www.summitracing.com/parts/mrg-1290
JeffB2 is offline   Reply With Quote
Old 07-15-2019, 05:11 PM   #3
grumppyoldman
Thanks Jeff, got em ordered. Al
Old 07-16-2019, 01:25 PM   #4
Ole Don
Ole Don's Avatar
I always carried two 9/16 wrenches to loosen the lower shock mount and lower the axle. I had lowering blocks, so mine may have been a bit off from when new.
Ole Don is offline   Reply With Quote
Old 07-17-2019, 05:36 PM   #5
grumppyoldman
Got the extensions installed, works good tire comes right ofrf now. Thanks for info. Al
Old 07-18-2019, 09:09 AM   #6
JeffB2
JeffB2's Avatar
Glad it worked for you
Old 07-28-2019, 01:04 AM   #7
Jwawhite
Jwawhite's Avatar
I installed a rear sway bar, the differential is now "connected" via clamps, sway bar/ bolted to frame.
The differential hangs just enough to push the lower portion of wheel inward to get wheel off studs. The body needs to raised a certain distance to work.
Heavy sway bars front and rear has greatly improved handling on the Frankenwagen.
Jwawhite is offline   Reply With Quote
Old 07-29-2019, 12:01 PM   #8
dmsfrr
dmsfrr's Avatar
Just something to watch out for...
How does the overall 'compressed' length of the shock compare?
If the shock with extensions is now too long the shock may bottom out before the axle hits its rubber bump stops. That can damage the shock internally, shortening its life very quickly.
dmsfrr is offline   Reply With Quote
Old 07-30-2019, 12:39 AM   #9
KULTULZ
KULTULZ's Avatar
The extenders would make the shock too short in it's designed travel and if it hits the internal stop, may well damage it.
Those things were designed for the few that jacked-up the rear without regard to proper shock travel or used air bags whereas the shock travel would not be that much different from stock travel.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-30-2019, 09:28 PM   #10
LD-Ordie
LD-Ordie's Avatar
Had the same problem on my 55 Courier. These extensions did the job
LD-Ordie is offline   Reply With Quote
