Old 07-15-2019, 03:20 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 59A Engine Fitted with Truck water pumps
59A Engine is fitted with the double pulley water pumps, truck type with bearings?
Do you require a special rebuild kit for these pumps due to the double pulley set up? Where to get these kits?
Thanks,
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 07-15-2019, 05:11 PM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 59A Engine Fitted with Truck water pumps
The rebuild kits contains a ballbearing and a bushing where the regular pump is bushing only.
The new kits that was sold seems to be gone...so NOS or if someone has piled up a bunch.
Old 07-15-2019, 06:55 PM   #3
JWL
I have several of those kits I purchased from Joblot a few years ago.
JWL is offline   Reply With Quote
Old 07-15-2019, 07:05 PM   #4
Phil Gillespie
Fred, Barnfind08 has come through for me. He has these NOS kits.
Appreciate advice.
Phil NZ
Old 07-16-2019, 12:09 AM   #5
Brian
Brian's Avatar
And the procedure to strip these pumps is somewhat different...Use a bearing separator around the pulley and, supporting the bearing separator in a press, press the pulley off of the shaft. After which, you can turn the pump housing over and support it on a suitable sized piece of pipe etc, and press the bearing out of the housing, leaving the impeller behind.
Old 07-16-2019, 12:31 AM   #6
Tinker
Tinker's Avatar
Those are nice if you have a old blower. Maybe sell them and get a single wide belt setup. Just a thought. less you are running 2 belts.
Old 07-16-2019, 12:48 AM   #7
Tinker
Tinker's Avatar
Their catalogs were epic.
Old 07-16-2019, 01:51 AM   #8
Phil Gillespie
Brian thanks very much for this dismantle info. Now no reason to break any bits off impellers. Just thought it would be good to overhaul them and have as spares.
Phil NZ
Old 07-16-2019, 08:01 AM   #9
Bored&Stroked
Bored&Stroked's Avatar
Hey - does anybody know if SKIP can rebuild these pumps and put his good impellers on them?
Old 07-16-2019, 08:34 AM   #10
KGS
KGS's Avatar
Yes, he does. Skip did two for me for my blower set-up.
KGS is offline   Reply With Quote
Old 07-16-2019, 02:48 PM   #11
supereal
supereal's Avatar
I would send them to Skip Haney. He does them for us. Usually, when installing a kit, the pulley is broken by trying to remove it. and a kit doesn't fix it. Skip is an expert. You can reach him at 941-505-9085.
supereal is offline   Reply With Quote
Old 07-17-2019, 01:45 PM   #12
deuce lover
deuce lover's Avatar
The man is in NZ.Might be very costly to ship them back and forth.
Old 07-17-2019, 02:02 PM   #13
flatheadmurre
Think i have a couple of complete NOS pumps if that helps...
Old 07-17-2019, 02:37 PM   #14
Phil Gillespie
Yes thats correct in NZ, and the dreaded shipping costs. Have some kits on the way from Barnfind08 and armed with Brian's info for dismantling these pumps should be good.
They will be" standby spares" when done.
Always appreciate advice and assistance offered on this site.
Phil NZ
Old 07-19-2019, 09:09 PM   #15
Phil Gillespie
Followed the above very clear instructions and now both pumps stripped awaiting spares to rebuild. Nil pulleys or impellers damaged during dismantle.
Used a strong back at bearing separator to remove pulley.
Then pressed out shaft from impeller in the vice. Thanks Brian.
Phil NZ
